Edge Evolution Gas Programmer
• Up to 40 HP and 38 ft. lbs. of torque
• Installs in minutes with no tools needed
• Includes a custom pod that makes the unit look factory installed
• Choose from four different power levels and display a host of vehicle parameters
• Internet updatable
• Adjustable color screen
PIDs:
• ECT (Engine Coolant Temp)
• TFT (Trans Fluid Temp)
• MPH
• RPM
• EOT (Engine Oil Temp)
• IAT (Intake Air Temp)
• SPARK (Spark Advance)
• MAF (Mass Air Flow)
• BARO (Barometric Pressure)
• MAP (Manifold Absolute Pressure)
• AAT (Ambient Air Temp)
• BATT (Battery Voltage)
• DIDL (Desired Idle)
• APP (Applied Pedal Position)
• EOP (Engine Oil Pressure)
• AFC (Air Flow Calculated)
• FUEL (Fuel Tank Remaining)
• LOOP (Loop Status)
• POWER (Power Enrichment)
• GEAR (Current Gear)
• AFP (Alcohol Fuel Percentage)
• DCYL (Deactivated Cylinders)
• DCD (Distance Cylinders Deactivated)
• DCA (Distance Cylinders Activated)
RECORDS:
• 0-60
• ¼ mile
• ECT
• RPM
• MPH
• SPARK
• AFP
• EOT
• EOP
• DCA
• DCD
• TFT
ALERTS:
• ECT
• MPH
• RPM
• IAT
• SPARK
• AFP
• TFT
• EOT
• EOP
• FUEL
This programmer will work on all GM gassers (New Body Style only), bought it new for $550 and im asking $450, it will work the 2500HD 6.0 but only levels 2-4, nothing wrong with the unit im just upgrading to a custom tune, it comes the dash pod for the regular dash or the custom bracket i built that fits in between the headliner and roof in the upper lefthand corner of the widshield, looks killer! it has the latest software updates aswell. E-mail me if interested thanks for looking!
PIDs:
• MPH
• RPM
RECORDS:
• 0-60
• ¼ mile
• ECT
• RPM
• MPH
• SPARK
• AFP
• EOT
• EOP
• DCA
• DCD
• TFT
ALERTS:
• ECT
• MPH
• RPM
• IAT
• SPARK
• AFP
• TFT
• EOT
• EOP
• FUEL
You paid too much!
