Inner Door Panel Removal?
Can someone please send me pictures or diagrams of how to remove the inner doorpanels on my 2007 2500HD Classic. I want to change my mirrors out and the pigtail for the electrical needs to be changed.
Thanks,
Mike
Thanks,
Mike
Here's a step by step I did with my 2000. It's not exactly the same, but the last post on the first page explains what should be different on your truck. Hope it helps
http://chevytruckworld.tenmagazines.com/ew..._2000_silverado
EDIT: Here's what he said would be different:
03-07 Classic Trucks are the EXACT same way EXCEPT For:
Window/Lock switch panel doesnt come off (So no bolt there)-
There is a little cap on the out side of the panel itself that hides a bolt-
I just had to change out my mirror on my '05 also. It is very simple. There are a few screws that you can see. One on each side of the outer jamb.One of these (I think the inner one) might just be a push-pin that you need to pop off with a small pry bar or something.There is one underneath the panel in the center that you will need to open the door to get at, and then the hidden one. This one you need to simply pop off the plastic molding that encircles the door handle. Simply pop that molding off with a small screwdriver or something and the screw is behind the molding at the base of the handle. This is the one that got me! And you will have to pop off the small molding pc. that surrounds the door lock latch. Them simply push up and release it from the hooks at the window part. All the wiring is pretty easy. After I post this, I will look for the post I put up a month ago when I smashed mine.
