Rear Gear Ratio
Lets set the table, I have a 2007 NBS crew cab silverado with 3.23. Rear ratio an is 2 wd. I am looking into replacing the rear ratio. I can get the ring and pinion for my truck @ 3.73 ratio for 189 dollars. Does any one know how much it would cost to have them installed? Also how much would it be if I were to bring it to my local dealer to do it to keep the warranty good? Any prices, tips or different opinions are greatly appreciated.
I would also love to know abou this, 189 is SUPER cheap for rear gears, and I would also like to move up to 3.73, and stick with the dealership for warranty reasons
WOW 189 bucks is darn cheap. Are they GM parts or aftermarket? Consider me another interested party. I'd like to hear any input on this as well.
GM will not warranty aftermarket parts. You cannot buy a set of GM ring and pinion gears for under $ 200. I would avoid cheap gears like this, as they may not have proper heat treat and machining tolerances. Suggest you get genuine GM gears from a discount source, such as gmpartsdirect, and have a GM dealer do the installation to get the warranty. Proper installation of gears require correct shimming, backlash adjustment, and proper gear contact pattern verification.
I agree with Pete's assessment of the warranty picture here, but I am still interested in finding out more about this swap. Warranty isn't a big concern to me.
Personally I am not afraid of good aftermarket parts. Our race toys never have anything OEM in their rear diff and they are bulletproof. (but they cost a lot more than 200 too)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
