Future Darwin Award Winners?
Zembonez
That could ruin your day
MAN, You are so right, why would you keep your beer that close to the hot plate?????
No kidding, and without coozies no less!
And don't get me started on the dangers of mixing Belgian ales with German porters. :rollin:
