Alternator Acting Up...
2008 Avalanche w/ 5.3L. I had it for about a month and I got less than 1100 miles on it now.
The Alternator started to act up a week ago. Half way home from work, it would drop to 12volts.
Like if the Alternator had turned off. I got home, turned everything off, checked the battery and
Alternator cables. All looks good. Re-start the engine and its back to 14.5volts.. Then, 2 days
later, it did it again. If I shut the engine and restart it, it goes back 14volts or so. Then, yesterday
it did it again. This time, it was at 12volts for about 6 miles and then went back to 14volts on its
own. I think the voltage regulator in the Alternator might be the issue.
This is driving me nuts. Some days its fine. If I take it the dealer, they won't do anything unless
they can duplicate it. Anyone seen anything like this before?
I think this is normal on 07 and 08. My Denali does the same thing. I heard they are much more aggressive in controlling the alternator based upon load. If the electrical load is low, it is shut off, if the load is high, it is in full charge mode. Mine will be over 14 volts and ten minutes later it is around 12. I believe they do this for for MPG. No sense stealing power from the engine if you don't currently need it.
My '06 does it. It is normal. There is a fuel saving system built into the charging circuit, which turns off the alternator when not needed. If the voltmeter stays between 12V and 15 Volts, you are fine.
Search the forum - there is a TSB on this issue explaining how the system works.
"If it ain't broke, don't fix it."
Wow! This is very good to know. Sounds like GM is doing whatever it takes to get that extra mile. It does make sense. Good thing I didn't take it in and waste my time at the dealer.
Thank you all... you guys rock!!!
It not that there going the extra mile, they're just conforming to the Al Gore tree hugers.
What's the carbon footprint of his armor plate limousine he rides in and the private jet he flies around in??? And why again does he need a $40,000 heating bil for his primary residence.
ok....sorry. Off topic.
