Possibly A Big Problem
Ok, so my truck does this really strange thing. At low Rpm, runs great, but when i hit above 3800, or 4000 Rpm, the truck runs hella lean, and has no power at all. Now I have changed my front o2 sensors before the cat (only cause the old ones died after 180k miles), and added a different muffler to it to get the low end back pressure back. Now I have used a scan tool to watch my fuel trims and everything looks to be in spec. So I was wondering if you guys had any idea what could be causing this. Thanks in advanced
Linderman
Well it isnt a race car, I mean it will pick up at 4000-6000 to a good point, but a 5000 lb rolling wall doesnt accelerate like a corvette. What leads you to believe that its running lean at that RPM?
Linderman
Fuel filter changed lately?
Linderman
Clogged cat?
Yea, I know it shouldn't be anything like a corvette, its just that its no where near how it was a couple of weeks ago. And I haven't had my fuel filter changed recently. Probably 85,000 miles ago, if not longer. And how would i check my cats to see if they are clogged?
I'd go ahead and change the fuel filter. It's cheap, easy, and you're past due.
And if your cat's are bad, your exhaust will smell BAD of rotten eggs.
Well currently my exhuast does smell, but thats because i have a new cat back system. So its the paint and stuff like that. But running a straight pipe, and lean could have burned up the cat, couldn't it?
Oh my. 85000 miles? Run to the parts store (RUN) and change that fuel filter out. It's cheap and easy, and it's something that needs to be done A LOT more often than you are doing it.
