Sierra Nbs Over Lolo Pass
OK, I drove US Hwy 12 west out of Missoula this past week. It climbs for 30 twisting miles and reaches it's highest point at Lolo Pass on the Montana/Idaho state line. Then it drops down into the steep and deep Lochsa River Canyon.
This year the snow level is unbelievable. The drifts at the Pass were over 20 feet deep, deeper than the semi's struggling over. The truckers were all running their tire chains on both tractor and trailer.
The regular plow crews had been called down off the Pass, and the super-large rotary snowblowers were digging a path through for the truckers. The force of the blizzard was incredible.
I carry chains for all four corners of my Sierra, but I just pulled the lever back into 4WD and continued on. I put my trust in the high-tech Stabilitrak, TC, G80 locker, 4WD, and BFG A/T's. No chains for me yet, but I was ready to put them on.
On the Idaho side, at Mile 132 a huge avalanche came down, completely closing the highway. No one was hurt, but about 6 semi's and myself could not move forward. No cell phone coverage, but most of the truckers had satelitte communications and were able to contact the authorities.
Suddenly, a second avalanche came roaring down at Mile 133, slamming into one of the trapped semi's. I could not believe my eyes as the fully-loaded semi was picked up like a toy and thrown down into the river canyon below. His fellow truckers were true hero's as they immediately started a rescue party. Fortunately, the driver was unhurt and he climbed out on his own.
After making sure he was OK, I was able to turn around on the narrow road, and headed to a Forest Ranger station for help. The truckers, who could not turn around, were trapped. The forest rangers, on snowshoes, were the first on the scene. The Idaho National Guard came in with a tracked vehicle and took out the stranded truckers, although their trucks are still up there. US Hwy 12 remains closed 7 days later.
2 things:
1st: the combination of Stabilitrak, TC, G80 locker, 4WD, and BFG A/T tires make an unbeatable snow vehicle. I have owned 7 other 4WD vehicles in my life, and this vehicle is by far the best in snow. Every one of the others would have required chains in these conditions.
2nd: Thanks to the brave plow crews of Montana and Idaho, the bravery of his fellow truckers, and the bravery of the Idaho National Guard and the US Forest Service, a trucker is alive today.
note: there are several articles about this in the Missoula paper: www.missoulian.com
wow! that sounds like it could be a movie. At least you didn't have to decide who to eat first.
Cool story, thanks for sharing. The only thing that would make it better would be to see a Tundra with a damaged tailgate stuck on the side of the road. :)
Having been driving mine in the snow, ice and cold since October I have found the same thing, I have been impressed with how this truck handles. its like driving on dry roads. Its the best truck I have had.
Yes it is really a beast on the snow. But once I turned into a Tim Horton's parking lot and as I was turning in the truck completely slid on it's side and I was 1-2 inches away from hitting a parked car. Was puzzled as why it did that with stabiltrak and traction on, but I did give it a little throttle. I was used to having the truck brake for me, but anyways this system is unbeatable.
I agree, it has been quite impressive. I was against these wide tires, but they have been doing quite well with the TC/Stabilitrak
Thats a good story I coudn't imagine seeing in person an avalnche take out a semi. But I do also agree that these trucks handle exceptionally in the snow, I wouldn't say better than my previous H2 but very comparable.
Wow! :)
I was up that way last Summer and the dry Interstate on a clear day scared the begeezus out of me at the Montana/Idaho line. Can't imagine driving in a blizzard. Glad everyone was OK.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
