Newbie From Va
pjbinchrist
Hello all,
Not new to forums, but I am new to this one. Don't have a Chevy Truck YET!
I joined to try and learn as much as I can about the Silverado 3500 DRW and/or the Kodiak 4500.
I plan on purchasing a Carriage fifth-wheel at the end of the year and want to buy a Chevy HD as a towing vehicle.
Hope to learn a lot.
Thanks.
