Can I Do This
Ok i have 97 chev k1500 that has a 5.7L it has had a minor fender fight that bent the frame the dealer cant pull it it is to messed up. I just got a 97 gmc k2500 that has a 454 in it that is has a rod knock. can i put the 5.7 from the chevy into the gmc if i can what do i need to change to do this any help will be taken to heart. i hope i can do this so my wife will not kill me for buying two trucks that dont run. she is a ford fan and like to rub in the fact that hers runs and mine dont please help thanks :lol::)
in the old days you could, I don't know about now. Besides, I'd rather push a Chevy than drive a Ford. A friend of mine has a Ford and he said Ford is an abbreviation
for F---ing Owner Really Dumb.
Now everybody knows it really means F__ked Over Rebuilt Dodge.
As far as the engine swap goes. If you have both (same year) trucks, there should be plenty of parts avaialble to do the swap. I don't know if the bell housing is the same or not between the two. Might have to use engine and trans out of the Blazer.
I'm sure somebody that has done it will chime in here.
yeah, its definitely do-able. You'll have to change the wiring harness and ECM, but thats about it. The trans may have a different bell housing, some do some don't, you can have a look at that once both drive trains are sitting side by side on the floor. The good news, the truck with the 454 should have a 12 or 14 bolt rear, which is much stronger than the one in the 1500.
Oh...you may have to swap drive shafts too...not sure if the 454 one is shorter than one from a truck with a 350, they shouldn't be....but you never know until you measure.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
