you guys are funny but you are so far off on who i am. that name is a kid that lives down the street from me ps vmax i still see your the same on tundra nation
Dave, if you actually own your own Tundra, how about some pictures of it? More specifically, so we know the truck is yours and not one you've found on the net, post a picture of a dollar bill resting on the steering wheel. That should help you prove you do, in fact, own a Tundra. If you want to post a picture of your first name on the registration, that's be another good way to prove it.
if i did that you would run out and by a tundra :thumbs:
And there, folks, is your answer. :lol:
Edited by daddy
  • Replies 391
Top Posters In This Topic
you guys are funny but you are so far off on who i am. that name is a kid that lives down the street from me that i dont like ps vmax i still see your the same on tundra nation
:lol::thumbs::thumbs: I don't care who ya are, that there is FUNNY!!! :lol::lol::lol:
Let's see....You don;t like him, so you impersonate him on a bunch of truck forums and act like a total :D to make HIM look bad..... :lol::lol::lol:
:lol::lol: i even keep hacking into his comp. and giving him virus's and had him arrested too just because i like him :lol::D
oh my God, kid...bow out gracefully and go away, you are just making yourself look even worse...LOL again, pathetic
:lol::lol: i even keep hacking into his comp. and giving him virus's and had him arrested too just because i like him :D:D
Oh really, and since you obviously don't like me, why haven't you hacked into my computer and given me viruses? Should I be updating my anti-virus software??? :lol:
Let's see if I have this straight....You are a grown adult and you don't like a kid down the street, so you impersonate him on a bunch of truck forums and act like a total :D to make HIM look bad..... :lol::lol::lol:
If you would have thought about it awhile, here is a lie that would have been somewhat believable:
You could have said you are Dave Sr and the Dave Morejon we found is your son..as in Dave Jr. Personally, I wouldn't have believed it, but someone may have. Certainly more believable than what you just came up with. :lol::lol::lol:
Since I have edited it, this is worthy of a re-quote.
I think little Davie is a bit confused :lol:
i like how you think you know my name :thumbs::thumbs:
Tell me Dave...Do you REALLY think we are that stupid? :lol::lol::lol:
your not worth my time continue on if it makes you feel good :D:D
i have to much fun here to do that :D:D
well that is fine with me, truly. Anybody that makes themself look this stupid, and enjoys doing so, is worth my time to abuse...carry on young man, there is no hope for you
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
    • I call B.S. when I first moved to Texas my first house would only cool to 80 with the Texas heat. The AC tech said it was normal at 100 degrees outside. I remodeled the house put in a new AC. I could hang meat. My cars may need recirculating to start. Once moving it switches to regular AC and I could hang meat. Living in Texas no one would put up with only 20 degrees difference.
    • AC in home or auto only cool down 15-25 degrees from outside temp, but what will help is to put the ac in recirc mode this will recirc the Inside cabin air rather then trying to cool down the outside hot air, I always have mine in recirc mode.
    • Found the fix for this.  Untightan the bolt just below top linkage on the steering column, turn assembly left to reduce space between the two linkage rods at the steering column, tighten bolt.  Made a big improvement.
