New From Nc
05Z
Just found site last night and made one post ( nobody answered but its cool) just bought a 05 crew cab z71 170,000 miles not a typo my brother-in-law cruzis timber and just drives them to death, he gets a new one every three years,and i thought i would take a chance for the money.theres my story for joining your site.
Welcome.
That may seem to be a lot of miles, but to put that many on they must have been mostly highway. Highway miles are much less stressful to a vehicle then half the amount of city miles. Hope you have good luck with your new truck.
All highway miles, trying to post pic off my cellphone(good pic from a cell phone)but cant get the computer to send it anywhere i will work on it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
