Ps Cooler Lines
alvocado
The power steering cooler line which runs from my gear box to the cooler is leaking at the clamp on the gear box fitting. The end attached to the cooler inlet line is press fit and my dealer parts department indicated I have to replace the entire cooler. I was disappointed to hear this considering the line looks like standard rubber cooler line. Has anyone successfully replaced just the rubber line and if so, how did you address the press fitting to the hard line at the cooler inlet and what type and OD line did you use? The cooler assembly GM part number is 15295846 for reference.
