Tow Haul = +mpg ?
I drive to work nearly every day and its a 22 mile drive and I have a MPG meter that consistently tells me I get 20.1mpg give or take 1 mpg
today I started driving home and thought I would put on tow/haul the whole trip just to see how bad it effects gas mileage. Well I was in a huge surprise, driving down the highway I noticed the MPG readout to by better than normal. plus I never dropped gears going up hills and MPG stayed high on the hills. when i got home I clicked the average button on the MPG readout and was surprised to see 21.98MPG for the trip, nearly 2mpg better than normal. (basically it stuck in 3rd gear the whole way home)
Has anybody else seen this before? This is the first time ive done this so it could be a fluke, but im going to do it again next time i go to work and see if it stays consistently good MPG.
Truck specs:
2000 Chevy Silverado
4.3L V6
slightly bigger tires
(dont know the differential size)
Im thinking the gearing is probably 3.6ish and I bet if I was to replace it with the 4.10 I would get better mileage due to less work of the engine.... at least according to my first test by driving in 3rd (tow/haul)
ANyone have any opinions or similar experiences??
when i have a box full of gear and a 3000lbs trailer, I notice that I get better mpg in tow haul mode then regular mode....I found in tow mode it drops to 4cyl more often than regular mode
I found that I get near the same MPG towing my 6500# camper. I get a little better than 14 not towing and between 10-11 towing in 3rd with the tow haul. Although I do live in a busy town and have to start and stop alot that probably explains my 14 MPG :lol:
This is interesting. Was your commute mostly highway or in town? I am tempted to try this, but my 50 mile commute round trip is on the highway going 70 mph. The truck should be fine, I guess. I will try it out today on the way home.
-al
In Tow/Haul it actually goes into 4cyl mode in 3rd gear. In regular mode if you put it in 3rd, it will not engage. So as long as you are going faster than 40 and slower than 60 you can be in 3rd AND in 4cyl mode. Pretty nice if you are places where the speed limit is 45-55. You can almost stay in 4cyl constantly due to the gearing.
my tow haul enables my truck to rev higher which leads to worser milage on my 4.8
Hmm... This is strange. Let's see if I understand this right; When you put it in TOW/HAUL mode, it switches to 4cyl mode more often. This is the opposite of what I would expect. I would think that when you put it in TOW/HAUL mode, it would cancel the 4cyl mode because it would have been designed for use when power from all 8 cylinders is needed all of the time. Unless the computer is expecting the engine to be working hard and since it doesn't detect anything close to what it should for TOW/HAUL mode, it just drops it into 4cyl. This probably doesn't make any sense, but this is the only reason I can see for this switch to 4cyl in TOW/HAUL mode.
In standard driving you can be in 4th gear at probably 20 mph. In Tow/Haul the earliest it shifts from 1st is 20, 2nd is 40, 3rd is 60. This mode was designed to allow the engine to stay in a lower gear making use of the added torque multiplier of the lower gear instead of making the engine work harder (and generate more tranny heat) by using a higher gear. The AFM (active fuel management) does not care if it is in either mode, just as long as the selector is in drive and the load on the engine is below a certain threshold (and a few other parameters like minimum speed, minimum engine temp, vaccuum, sunspot location, etc...)
Good point.
Another reason you get a little better MPG (driving below 60) in tow/haul is that in some gears (1st, 2nd, and I think even 3rd) when you let off of the accelerator, the tranny will Free Spool (watch the tach drop to idle even when you are doing 40). No engine drag=better MPG while coasting.
Now if only we could set the truck to default to tow/haul mode everytime unless you switch it back. Tow/haul during the week going to work, non tow/haul on the weekends.
Interesting thread, I'll start giving it a try.
won't using tow/haul on a daily basis when not actually needed cause excessive wear or hurt anything?
Shouldn't cause any additional wear. I think that the only way that you could hurt it is to not let the engine catch back up if you are rolling and the tranny is free-spooling. Idle to 3k rpm only to slam into 2nd gear sure freaks the kid out next to you but it is probably not too good for it... Just give it a bit of gas to let it catch back up and then when it does drive it like you normally would. Hope the free-spooling makes sense. If it does not, put it in tow/haul and drive on a road where the speed limit is 35. You will immediately know what I mean.
Used Tow/Haul (about 250 miles round trip) a few weeks ago while towing a trailer with a snowmobile on it, did not notice any MPG improvement. But I did notice that when I switched to tow/Haul mode, my transmission temp went up about 10 degrees, this was about 50 miles into the trip that I turned on the tow/haul mode.
On the way back tow/haul was already on, when I got close to home I turned it off, no transmission temp difference.
Just a fluke, I do not know. Will have to give it another try some time.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   4 Members, 0 Anonymous, 609 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
