O2 Sensor, When To Change ?
Hi!
My truck has about 60k miles on it, and I think it still has the original O2 sensor. I posted a while back about how bad my gas mileage was (10MPG) and got the injectors cleaned, as well as the "butterfly valve", the filters were still clean. That didn't seem to help too much, but still, it was a used truck I bought so it is still a good thing to do.
Now I hear O2 sensor can really affect gas mileage. What is the typical interval O2 sensors need to be changed ?
What's low? No codes? Heavy foot? Stock wheels? City/hwy ratio?
10 MPG. I wouldn't know about codes since I am not equipped to read ODBI (or whatever it is called). Tires are 245/75R16 TractionKing Plus (snow tires). I try to always keep it under 1500rpm in the city, 75/25 city/highway.
Thought I should get at least 12-14MPG and 13-15 when summer gas mix comes back.
Bad O2 would give a check engine light. Thats pretty weak mileage, even w/75% city, unless you're idling half the time. You may need to run some injector cleaner through it. I'm sure that there can be a big discussion here about which and how much, but a good quality gas treatment like Techroline for a couple of tanks may improve it greatly. Could even run it a little higher concentrate than recommended; like 3/4 tank to the can of treatment.
Already had the injectors cleaned, but maybe I'll try that treatment of yours.
Thanks :shakehead:
If a shop has cleaned the injectors don't waste your money. If it was the $99 treatment with the can in the fuel rail that should be about it on that. How about that air filter?
The one that is in the truck is still very clean, white.
Have you had it checked for the latest 'puter info?
Also, I believe that an O2 sensor can read slow. Have it checked with a big $ handheld to monitor the O2 output.
On mine, it gets dirty real fast and swings slow enough that a knowledgeable tech can observe/interput the O2 readings.
My 2¢
<br />Have you had it checked for the latest 'puter info?<br /><br />Also, I believe that an O2 sensor can read slow. Have it checked with a big $ handheld to monitor the O2 output.<br /><br />On mine, it gets dirty real fast and swings slow enough that a knowledgeable tech can observe/interput the O2 readings.<br /><br />My 2¢<br />
<br /><br /><br />
+1
O2 sensors have a wide tolerance before they pop a code. Your gas mileage will be affected before a code is popped. I would replace them between 75K and 100K (closer to 75 if mostly city driving, closer to 100 if mostly highway).
Just my opinion.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
