Neutron Posted April 8, 2008 Posted April 8, 2008 How closely related is the 4.3L V6 and the 5.3L V8 as far as design?
Zembonez Posted April 8, 2008 Posted April 8, 2008 How closely related is the 4.3L V6 and the 5.3L V8 as far as design? They are 2 completely different generations from GM. The 4.3 is based on the old 5.7 (350) and the 5.3 is a new generation engine.
fiero2m4 Posted April 8, 2008 Posted April 8, 2008 How does the 4.8L V8 relate to these two? (old vs. new gen) How closely related is the 4.3L V6 and the 5.3L V8 as far as design? They are 2 completely different generations from GM. The 4.3 is based on the old 5.7 (350) and the 5.3 is a new generation engine.
Bish Posted April 9, 2008 Posted April 9, 2008 How does the 4.8L V8 relate to these two? (old vs. new gen) How closely related is the 4.3L V6 and the 5.3L V8 as far as design? They are 2 completely different generations from GM. The 4.3 is based on the old 5.7 (350) and the 5.3 is a new generation engine. 4.8 and 5.3 are pretty much identical except for displacement.
jrrod2004 Posted April 9, 2008 Posted April 9, 2008 Isn't the 5.3 a variant of the 305? believe so.....not a tech though
hotrodzz4 Posted April 9, 2008 Posted April 9, 2008 the 4.8 and 5.3 are based on LS engine architecture, but with iron blocks on all 4.8s and on some 5.3s.
Zembonez Posted April 10, 2008 Posted April 10, 2008 Isn't the 5.3 a variant of the 305? NO. 305 is also an old generation small block like the 350. As was the 283, 327, etc. 4.8, 5.3, 6.0 and 6.2 are new generation engines.
ColoradoSkiCountry Posted April 11, 2008 Posted April 11, 2008 The price of gas and the amount of taxes I have to pay...
silveradocoa Posted April 11, 2008 Posted April 11, 2008 tink of it like this, 4.3 is related to the LT motors, 5.3 is an LS variant
pckhalil Posted April 12, 2008 Posted April 12, 2008 From my understanding the 4.3 V6 is basically the same architecture as the old 5.7 V8, just with two less cylinders. Look at the displacements: 5700/8 = 712.5 cc per cylinder. 4300/6 = 716 cc per cylinder. Ford tried a similar thing awhile back, using the architecture of their 351 V8 to create a V6 and it didn't work out so well. The 5.3 is completely different. The 4.8 is a destroked and debored version, while the 6.0 and the 6.2 are stroked and bored versions.
VMax2007 Posted April 12, 2008 Posted April 12, 2008 From my understanding the 4.3 V6 is basically the same architecture as the old 5.7 V8, just with two less cylinders. Look at the displacements: 5700/8 = 712.5 cc per cylinder. 4300/6 = 716 cc per cylinder. Ford tried a similar thing awhile back, using the architecture of their 351 V8 to create a V6 and it didn't work out so well. The 5.3 is completely different. The 4.8 is a destroked and debored version, while the 6.0 and the 6.2 are stroked and bored versions. Pretty sure the 4.8 and the 5.3 have the same bore. Not 100% positive though.
slix42 Posted April 13, 2008 Posted April 13, 2008 the 4.8 and the 5.3 are almost identical. the only real difference is the stroke and the top of the pistons from my understanding
svensk Posted April 13, 2008 Posted April 13, 2008 the 4.8 and the 5.3 are almost identical. the only real difference is the stroke and the top of the pistons from my understanding yup
