"service Airbag Soon"
Well, my airbag light had been flashing intermittently for the past couple of days, and then this morning it was solid, and my DIC read "Service Airbag Soon". And that is why I am now driving mom's Avalanche around and waiting for a call from the dealer. I was due for an oil change anyway, so I was able to kill 2 birds with 1 stone, at least. I just think its odd that I already had something like this happen (unless its a false code) since I've only had the truck since Sept and has a mere 5900mi on it. Anyone else experience this issue?
I had this happen once. I saw the message on the DIC the second I started the truck, then it died immediately. It started back up and never got the light again. I also get the service traction control message occasionally. But when I took it to the dealer, they said there was nothing to check since the messages had gone away and no codes were being thrown at the time. Very aggrevating since I had to have my truck retuned to the stock settings.
I think that if a vehicle was taken to the dealer with a missing drive shaft they would stand around and shrug their shoulders if there wasn't a OBDII code.
I had the service airbag light come one when my truck was new. Turned out there was a short under neath the dash cuasing it to blow fuse #46.
Mine was on in my 04 because the one of the wires to the Seat Position Sensor under the driver seat broke off. Poor design in my opinion, because if you need to move the seat alot (for me it's getting my kids in and out of the back seat) it's prone to break. Luckily, i had access to a scan tool and was able to pick up a new pin for the wire and fix it for a couple bucks.
I assume your light stayed on until the short was fixed and fuse replaced?
Bring it over to us we just unwrapped our j-32666 crystal ball and oujia board no more diagnosing we just ask the spirits now.
Just wait until the message says "Service Airbag NOW!!!" and you'll be fine. :lol:
I agree with Hubbycap...if it doesn't throw a code the dealer is clueless even if the problem is obvious. Your problem is probably a bad sensor and if the light is staying on the code should be there for the dealer to see.
Correct, the fuse actually blew twice. The first time the dealer just replaced it but the second which was the next day they found the short.
Good one Mike, just being a smartass. :lol:
As these things increase in sophistication so does our reliance on computer controls, it would seem that transient errors would be stored for further study.
Is there some way for you to force it to save a snapshot of what is going on? A buddy of mine told me a while back that the Saturn dealer told him that if he turned the cruise on and off like three times and then did something else it would save a snapshot and that the dealer could see what was going on at that specific time.
BS or real?
You and I would think so but they are stored on priority and we don't make the priorities the programming engineers do.
Well I guess items connected to life/safety are just a low priority. :thumbs:
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
