Gmpp Air Intake Kit
Yeah, works fine, just as well as any other enclosed intake. :thumbs: But do a search, you'll find lots of info on intakes in general, including the GMPP intake.
  • 1 month later...
How does the performance compare to a K&N FIPK?
It looks nice, but if the performance isn't there the looks wouldn't be worth the extra money.
Its a great kit, just costy, but you do get what you pay for.
+1
I've got one in my '07 and it is great. You wont be disappointed.
+1
I agree.
If you are looking for performance or mileage, get it tuned first.
Considered this one myself, seems someone had a line on an ebay seller where it was a little cheaper, you might search for that.
