2007 Nbs Silverado Battery Going Dead
My '07 just started going dead. Any updates?
This thread is very old. My 08 started acting up and the battery was bad. That is probably what is wrong with you 07. It lasted longer that I would have thought.
  • 1 month later...
  • Replies 37
I have an 08 LTZ with only 20,000 in it and I am on my 3rd battery. Local dealer says nothing is wrong with the truck, I find that very hard to believe since i have NEVER gone through this many batteries in a truck. Has anyone else experienced this? Also I live in Florida, so no cold battery killing weather and I have NO after market accessories in the truck.
I am on my second battery for my 2007 NBS (going on 1.5 years). It has been OK until a few weeks ago when I was getting new tires installed at the local tire place. I went to back out the truck and ''click click click".
Disclaimer: The only mod is I have the OEM Onstar Bluetooth module which results in the "Red" led on the mirror.
After a quick jump (by a Ford F150 I might add) I drove straight over to the dealer. The checked the battery and every thing was OK, except that the fact that the 710 CCA value was closer to 630 CCA. I had all the TSB's done previously and no problem since.
The only thing that stuck out at me at the time was when they used their handheld computer to reset/set the TPMS. I am assuming that they may have turned the key into the run position for this. Other than that the truck sat for only an hour or so with the tire change over with the key in the ignition (but off).
This truck is driven maybe 3-4 times a week and now in rather short (~10 mile) trips. It starts fine. It did sit for 10 days this past summer and it still cranked right up.
One thing that I have noticed is that physically the battery is rather compact vs the amperage capacity. I also suspect that the build material quality is probably a little underwhelming in this day of cost cutting.
Wow, only 20k on an 08. It thought my 08 with 29k was doing well. Maybe you don't drive enough / or far enough on your trips to keep the battery charged?
my thermo keeps resetting to 74 degrees and it's getting very difficult to cold start in the morning..
had it die on me at the carwash after drying the truck off and listening to music for 5 mins while toweling down..
it happened to me last year too when it got cold.
mine's an 07. time for a new battery or maybe other issue?
Getting the battery checked at the local parts store is the easiest thing you can do to find your problem. Any comments/suggestions from anybody on here are at best speculation. Go by Autozone, and they'll do a load test to see if your battery has a bad cell. Good luck, and let us know how it turns out.
On the NBS, there was a TSB for bad battery connections (ground I believe), BCM not powering down so it drained the battery, and one they don't mention: GM batteries are crap (these new ones).
In your case, I doubt it's the BCM. I'd suspect either battery connection or bad battery. I had my '00 for 8 years with no issues with the battery. Within 1.5 years, my '08 was killing the battery in a week.
  • 1 month later...
Well it bit me again..this time in the local supermarket parking lot. It started just fine in the garage and it was on the road for about 12 miles. Came out after only 15 minutes and "click, click, click...". I received a quick jump from a fellow Chevy pickup and was my way.
I guess a new battery is in order. These are not lasting worth a damn. My previous truck had the OEM Delco for over 7 years. This would make my third battery in 4 years. Of course the dealer had replaced the original with a higher CCA under warranty and despite my issue last month declined to replace the battery because it tested out "fine".
Any recommendations on replacement?
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
