I realize there are many post about the new 07 08 GM fog light bulbs. Everyone is having the same problem. I want to know what yall had to do in order to make the 9005 bulb fit into the new silverado fog light. If I could modify it to fit like some ppl have said they have i would get HIDs but i don't want my headlights and fogs not to match....
Might do a search for fog lights. I've seen some threads discussing them in here. I've never even turned mine on.
