Wheel Shopping Question
Hey all. Doing some new rim shopping for a 2008 Chevy Z71. Do I want hub centric or not? Thanks.
YES!
Hub centric wheels eliminate many vibration issues by centering the wheel to the hub rather than letting the lugs do it by chance. All decent wheel manufacturers offer hub centric rings to make their wheels hub centric for your application.
If you're internet shopping, most sites will have a chart or table that lists the size, bolt pattern, offset, backspacing, max load, etc. If you find two wheels that seem to have the same specs. One may have the letters "hc" after the model number, or there may be an asterek (*) by the ones that are hub centric.
Plus, you could always call the company to find out for sure. Hope that helps.
