Help With Specs.
dost
i hava a 1998 gmc 3500 v8 6.5l turbo diesel truck, can
some one give me the torque specs. for the engine head.
it would be nice if i can get all specs. for the engine.
thanks, tubay. :(
Accessory/Engine Lift Bracket Nut and Bolts
50 N·m
37 lb ft
Bell Housing Bolts
40 N·m
30 lb ft
Camshaft Gear Bolt
170 N·m
125 lb ft
Camshaft Thrust Plate Bolts
25 N·m
17 lb ft
Connecting Rod Cap Nuts
65 N·m
48 lb ft
Coolant Crossover Bolts/Studs
42 N·m
31 lb ft
Coolant Drain Plugs
25 N·m
18 lb ft
Crankshaft Balancer Bolt
270 N·m
200 lb ft
Crankshaft Bearing Cap Bolts
(Inner Bolts-12 mm) First Pass
75 N·m
55 lb ft
(Inner Bolts-12 mm) Second Pass
75 N·m
55 lb ft
(Inner Bolts-12 mm) Final Pass
+ 90 Degrees
(Outer Bolts-12 mm) First Pass
65 N·m
48 lb ft
(Outer Bolts-12 mm) Second Pass
65 N·m
48 lb ft
(Outer Bolts-12 mm) Final Pass
+ 90 Degrees
(Outer Bolts-10 mm) Single Pass
40 N·m
30 lb ft
Crankshaft Pulley Bolts
50 N·m
37 lb ft
Crankshaft Sensor Bolt
23 N·m
17 lb ft
Cylinder Head Bolts
First Pass
25 N·m
20 lb ft
Second Pass
75 N·m
55 lb ft
Third Pass
75 N·m
55 lb ft
Final Pass
+ 90 Degrees
Exhaust Manifolds Bolts
35 N·m
26 lb ft
Flywheel Bolts
90 N·m
65 lb ft
Front Cover Bolts
45 N·m
33 lb ft
Fuel Filter Mount Bolts
42 N·m
31 lb ft
Fuel Filter Water Drain Valve Stud
41 N·m
31 lb ft
Fuel Injection Line Fittings to Fuel Injection Pump
33 N·m
24 lb ft
Fuel Injection Line Fittings to Fuel Injection Nozzles
33 N·m
24 lb ft
80 N·m
59 lb ft
Fuel Injection Pump Gear Retaining Bolts
25 N·m
20 lb ft
Fuel Injection Pump Nuts
40 N·m
30 lb ft
Glow Plugs
22 N·m
16 lb ft
Intake Manifold Bolts/Studs
42 N·m
31 lb ft
Oil Cooler Line Fittings
75 N·m
55 lb ft
Oil Fill Neck Nuts
23 N·m
17 lb ft
Oil Filter Adapter Bolt
63 N·m
47 lb ft
Oil Gallery Plugs
34 N·m
25 lb ft
Oil Level Indicator Tube Bracket Bolt
4 N·m
35 lb in
Oil Pan (All Except Rear Two Bolts)
10 N·m
89 lb in
Oil Pan (Rear Two Bolts)
23 N·m
17 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pump Bolt
90 N·m
65 lb ft
Oil Pump Cover Screws
16 N·m
12 lb ft
Oil Pump Driver Clamp Bolt
42 N·m
31 lb ft
Thermostat Housing Bolts/Studs
47 N·m
35 lb ft
Turbocharger Connector Hose Clamps
6 N·m
50 lb in
Turbocharger Exhaust Manifold Mounting Nuts
58 N·m
43 lb ft
Turbocharger Long Brace Bolt
50 N·m
37 lb ft
Turbocharger Long Brace Nut
34 N·m
26 lb ft
Turbocharger Oil Feed Line Fittings
28 N·m
21 lb ft
Turbocharger Oil Return Pipe Bolts
26 N·m
19 lb ft
Turbocharger Short Brace Bolts
25 N·m
18 lb ft
Upper Intake Connector Hose Clamps
6 N·m
50 lb in
Upper Intake Manifold to Intake Manifold Bolts
23 N·m
17 lb ft
Valve Lifter Guide Plate Clamp Bolts
27 N·m
20 lb ft
Valve Rocker Arm Cover Bolts
27 N·m
20 lb ft
Valve Rocker Arm Shaft Bolts
55 N·m
40 lb ft
Water Pump Plate to Coolant Pump Bolts
28 N·m
20 lb ft
Water Pump Plate to Front Cover Bolts
28 N·m
20 lb ft
Water Pump to Front Cover Bolts
42 N·m
32 lb ft
Application
Specification
Metric
English
50 N·m
37 lb ft
Bell Housing Bolts
40 N·m
30 lb ft
Camshaft Gear Bolt
170 N·m
125 lb ft
25 N·m
17 lb ft
65 N·m
48 lb ft
42 N·m
31 lb ft
Coolant Drain Plugs
25 N·m
18 lb ft
270 N·m
200 lb ft
75 N·m
55 lb ft
75 N·m
55 lb ft
+ 90 Degrees
65 N·m
48 lb ft
65 N·m
48 lb ft
+ 90 Degrees
40 N·m
30 lb ft
50 N·m
37 lb ft
23 N·m
17 lb ft
Cylinder Head Bolts
First Pass
25 N·m
20 lb ft
Second Pass
75 N·m
55 lb ft
Third Pass
75 N·m
55 lb ft
Final Pass
+ 90 Degrees
35 N·m
26 lb ft
Flywheel Bolts
90 N·m
65 lb ft
Front Cover Bolts
45 N·m
33 lb ft
42 N·m
31 lb ft
41 N·m
31 lb ft
33 N·m
24 lb ft
33 N·m
24 lb ft
80 N·m
59 lb ft
25 N·m
20 lb ft
40 N·m
30 lb ft
Glow Plugs
22 N·m
16 lb ft
42 N·m
31 lb ft
75 N·m
55 lb ft
Oil Fill Neck Nuts
23 N·m
17 lb ft
63 N·m
47 lb ft
Oil Gallery Plugs
34 N·m
25 lb ft
4 N·m
35 lb in
10 N·m
89 lb in
23 N·m
17 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pump Bolt
90 N·m
65 lb ft
16 N·m
12 lb ft
42 N·m
31 lb ft
47 N·m
35 lb ft
6 N·m
50 lb in
58 N·m
43 lb ft
50 N·m
37 lb ft
34 N·m
26 lb ft
28 N·m
21 lb ft
26 N·m
19 lb ft
25 N·m
18 lb ft
6 N·m
50 lb in
23 N·m
17 lb ft
27 N·m
20 lb ft
27 N·m
20 lb ft
55 N·m
40 lb ft
28 N·m
20 lb ft
28 N·m
20 lb ft
42 N·m
32 lb ft
Nah... that's not it. Torque every bolt on your truck to 57,000 ft/lbs and come back when you are done!
Good post BlueGorilla!
Wow, scrolling down through all those specs got me dizzy. :(
Well, if you are anything like me that doesn't take much!
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
    • I just did a little bit more research, and it seems that this Avalanche is not a Global-A vehicle, because the charts seem to list several models that were Global-A starting in 2010, but the Avalanche is not on there. And even similar models such as the Silverado are not on the Global -A platform until later in 2013. Please correct me if I'm wrong.
    • Yes, the 2007 is a GMT 900. Originally I had ruled out computers/compatibility as a problem because I did not change over any computers, only the engine. I know that the motors are different codes, but it seems like the lmg to lc9 is a fairly common swap, at least from what I can read online. I'm using all the wiring and sensors from the 2010 vehicle, as well as the computers (the only exception to that being the MAP sensor).
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
