New Exhaust
I just got a new flowmater 40 series from the cat back on my 99 5.3 the thing barely makes any sound the garage told me beacause of the cats on it. Really sucks to spend 300.00 and sound almost stock. Does anyone else have this and what type of sound do you have
Bryan
I have the delta flow 40 muffler. It's pretty loud, much louder than stock. Just replaced the muffler and thats all.
I'm guessing for 300 all they did was slap a single in, dual out flowmaster on there. Definately wont be as loud as true duals. Your setup should be more loud than stock though.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
