I was thinking about putting some wider tires on my truck...i just think the truck will have a little bit better stance...anyway im getting a leveling kit soon or maybe a 3inch lift so could i fit something wider than the 265/70r17 and if so what size could i put on my 17x8.5 wide rim?
Your 8.5" wide rims will give you a lot of flexibility. I think your more dependent upon rubbing that what your rims could handle. That 3" lift should be perfect to fix that.
This has been covered extensively on this site. I don't have any solid answers for you but you could try searching. There's a ton of "what tire?" threads available here. :thumbs:
if you just want to go wider without going taller then your options are 285/65, 305/60...for every +20mm in section width subtract 5 from the aspect ratio to keep the same overall diameter. I don't know what tires are available in these other sizes or how wide will really fit without rubbing, I'm just pointing out the easy method for figuring out how to go wider without increasing OD.
Search for some reason does not work on my computer. It works but it takes like 10 minutes to get the results.
Also curiosity kicking up again :thumbs: what would be a cheap way to get about 3 inches of lift without:
1. Not making the ride quality suffer a bunch
2. Not using a body lift
C. Not spending a ton of cash.
All im looking to do is fit 295/70R17
1. Not making the ride quality suffer a bunch - Body lift
2. Not using a body lift - Nevermind, go with a suspension lift
C. Not spending a ton of cash. - Nevermind, crank the hell out of the torsion bars. Oh wait that'll make it ride like crap (and wear the hell out of suspension components)
Jackstands are the only thing left. :(
Your best option IMO is either spend the money for a suspension lift, or go with a body lift. There is absolutely nothing wrong with a BL, it's a great safe, inexpensive way to fit larger tires.
