6.2l & 6spd Tranny?
Convinced the wife to get the Yukon Denali mainly to get teh 6.2L engine and the 6 speed tranny. Not disappointed at all!
Wondering when the light duty trucks will be getting this combination? I've been holding off on even looking at new truck until at least the 6 speed becomes available. Any word?
Thanks Cueva! Encouraging news.
Now if GM would only give me heated AND cooled leather seats...and give them to me in the LT packages :devil:
I'm dreaming, I know...
Thank MS3DALE, he is the one that showed me where it was in Dealerworld
Yep,Coming next year.
Just remember the 6-spd will be across the board on all models with the 6.0/6.2,and on all models with the 5.3 except the extended-cab short-bed models (C/K10553)
However the 6.2 will only be available in the crew-cab LTZ trim level trucks.
The 4.3-V6 and 4.8-V8 models are still limited to the 4-spd.
Of course, the 6.2 w/ the 6-speed is already available in the Sierra Denalis, too.
+1 Technically the answer to your question is since 2007 NNBS 1500 Sierra Denali Crew 5'8" bed 2WD and AWD in Black, White, Silver Birch
I've got the 5.3 in a Crew Cab Sierra 07, and I've got a Yukon Denali 07 for the wife and the 6.2 liter 6 speed combo is awesome. The 5.3 does get the job done in the truck, althought I would not mind what's under the hood of the Yukon.
True, but that is an AWD "wannabe" truck. :sigh:
J/K!!! :devil:
J/K!!! :devil:
Only if you pay extra for for the "AWD/let's-make-it-less-fun" option. :lol:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
