Exhaustst Manifold To Engine & Y-pipe Bolt Torques
I have an 06 silvy w/ the 5.3L engine. What are the torques of the exhaust manifold bolts and the bolts/nuts that attach the manifold to the Y-pipe.
Thanks
gmLogoFlat.gif Service Information
2006 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 878378 Exhaust Manifold Replacement - Left Side (4.8L, 5.3L, and 6.0L Engine)
Removal Procedure
  2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle .
  3. Remove the exhaust manifold pipe nuts.
  4. Lower the vehicle.
  5. Remove the spark plugs. Refer to Spark Plug Replacement .
  6. Remove the exhaust manifold bolts, manifold, and gasket.
  7. Discard the gasket.
  8. Remove the heat shield bolts (3), and shield (2) from the exhaust manifold (1), if necessary.
  9. Clean and inspect the exhaust manifold. Refer to Exhaust Manifold Cleaning and Inspection .
Installation Procedure
    Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the heat shield (2), and bolts (3) to the exhaust manifold (1), if necessary.Tighten
    Tighten the bolts to 9 N·m (80 lb in).
    Important:
    Tighten the exhaust manifold bolts as specified in the service procedure. Improperly installed and/or leaking exhaust manifold gaskets may affect vehicle emissions and/or On-Board Diagnostics (OBD) II system performance.
    The cylinder head exhaust manifold bolt hole threads must be clean and free of debris or threadlocking material.
    Important: Do not apply sealant to the first three threads of the bolt.
  3. Apply a 5 mm (0.2 in) wide band of threadlock GM P/N 12345493 (Canadian P/N 10953488), or equivalent to the threads of the exhaust manifold bolts.
  4. Install the exhaust manifold, NEW gasket and bolts.Tighten
    1. Tighten the bolts a first pass to 15 N·m (11 lb ft). Tighten the bolts beginning with the center two bolts. Alternate from side-to-side, and work toward the outside bolts.
    2. Tighten the bolts a final pass to 25 N·m (18 lb ft). Tighten the bolts beginning with the center two bolts. Alternate from side-to-side, and work toward the outside bolts.
[*]Using a flat-punch, bend over the exposed edge of the exhaust manifold gasket at the rear of the left cylinder head.
[*]Install the spark plugs. Refer to Spark Plug Replacement .
[*]Raise the vehicle.
[*]Install the exhaust manifold pipe nuts.Tighten
Tighten the nuts to 50 N·m (37 lb ft).
[*]Lower the vehicle.
© 2008 General Motors Corporation. All rights reserved.
2006 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 826358 Exhaust Manifold Replacement - Right Side (4.8L, 5.3L, and 6.0L Engines)
  5. Remove the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement .
  6. Remove the spark plugs. Refer to Spark Plug Replacement .
  7. Remove the exhaust manifold bolts, manifold, and gasket.
  8. Discard the gasket.
  9. Remove the heat shield bolts (1), and shield (2) from the exhaust manifold (1), if necessary.
  10. Clean and inspect the exhaust manifold. Refer to Exhaust Manifold Cleaning and Inspection .
  1. Notice: Refer to
Fastener Notice in the Preface section.
Install the heat shield (2), and bolts (1) to the exhaust manifold (1), if necessary.Tighten
Important:
Service Information
2006 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1684766
Fastener Tightening Specifications
Application
Specification
Metric
English
Catalytic Converter Coupling Nut
45 N·m
33 lb ft
Exhaust Gas Recirculation (EGR) Cooler Tube Nut (6.6L)
30 N·m
20 lb ft
Exhaust Hanger Bracket Bolt
12 N·m
106 lb in
Exhaust Heat Shield Bolt (Body Panel)
9 N·m
80 lb in
Exhaust Heat Shield Nut (Body Panel)
9 N·m
80 lb in
Exhaust Manifold Bolts (4.8L, 5.3L, and 6.0L)
First Pass
15 N·m
11 lb ft
Final Pass
25 N·m
18 lb ft
Exhaust Manifold Bolt/Nut (6.6L)
34 N·m
25 lb ft
Exhaust Manifold Bolt/Stud (4.3L)
30 N·m
22 lb ft
Exhaust Manifold Center Bolt (8.1L)
35 N·m
26 lb ft
Exhaust Manifold Heat Shield Bolt (4.3L, 4.8L, 5.3L, and 6.0L)
9 N·m
80 lb in
Exhaust Manifold Heat Shield Bolt (6.6L)
8 N·m
71 lb in
Exhaust Manifold Heat Shield Bolt/Nut (8.1L)
25 N·m
18 lb ft
Exhaust Manifold Nut (8.1L)
16 N·m
12 lb ft
Exhaust Manifold Pipe Nut
50 N·m
37 lb ft
Exhaust Muffler Hanger Nut
50 N·m
39 lb ft
Exhaust Muffler Nut
40 N·m
30 lb ft
Exhaust Outlet Pipe Clamp (6.6L)
15 N·m
11 lb ft
Exhaust Outlet to Right Exhaust Pipe Bracket Bolt (6.6L)
34 N·m
25 lb ft
Exhaust Pipe Clamp
44 N·m
33 lb ft
Exhaust Pipe Hanger Bracket Bolt
12 N·m
106 lb in
Exhaust Pipe Hanger Bracket Bolt (4L60-E)
17 N·m
13 lb ft
Exhaust Pipe Heat Shield Bolt (6.6L)
8 N·m
71 lb in
Exhaust Pipe to Manifold Bolt (6.6L)
53 N·m
39 lb ft
Exhaust Pipe to Turbocharger Bolt (6.6L)
53 N·m
39 lb ft
Hood Hinge Bolt
25 N·m
18 lb ft
Intake Manifold Cover Clamp (6.6L)
6 N·m
53 lb in
Oil Level Indicator Tube Bracket Bolt (6.6L)
21 N·m
15 lb ft
Outlet Duct Clamp
6 N·m
53 lb in
Oxygen Sensor
42 N·m
31 lb ft
Rear Shock Absorber Lower Bolt
95 N·m
70 lb ft
Spark Plug (4.3L)
15 N·m
11 lb ft
Spark Plug Wire Retainer Bolt (4.3L)
12 N·m
106 lb in
Transmission Bolt
100 N·m
74 lb ft
Transmission Fluid Fill Tube Nut (6.6L)
18 N·m
13 lb ft
Transmission Mount to Support Nut
40 N·m
30 lb ft
Transmission Support Crossmember Bolt
95 N·m
70 lb ft
Turbocharger Exhaust Pipe Bolt/Nut (6.6L)
53 N·m
39 lb ft
Turbocharger Exhaust Pipe Heat Shield Bolt (6.6L)
8 N·m
71 lb in
Turbocharger Heat Shield Bolt (6.6L)
9 N·m
80 lb in
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
