Intermittent Grinding Feel From Steering Wheel
slemmer
Good luck on this one: on my 60,000Kms '05 CCSB I had the intermediate steering shaft replaced (a few times). With this most recent episode, when I turn the steering wheel either left or right, (no hard or fast turning), the odd time I get a grinding/rubbing/friction vibration/sensation through the steering wheel. This doesn't happen all the time, but it occurs at any temperature.
I brought it into the dealership and the tech was able to repeat what I described on several occasions. They gave me the truck back today without the column cover to see if that is the cause of the problem. The trim tech is stumped. Out of the blue they're going to order me a lower steering bearing to see if that may be the issue. Has anyone had this issue occur to them?
Thanks
Stephen
Thanks
Stephen
If they figure that out i'd love to hear what it is!! My 04 100, 000km has done that since 60 000. It started at random, the dealer i took it to was stumped aswell. Now it always does it and much louder... I've driven others, my trucks steering is much stiffer in comparison. You'd almost think the pump/reservoir was empty, but its fine! I was just about to change the shaft, maybe i'll hold off!
Thanks
Stephen
Well, after the bearing was changed out the problem has disappeared. I'm not the 2nd of two reported cases on file at the GM tech center! Good luck with your fix.
Maybe im feeling the same thing you are....maybe Im not...hard to explain
Seems that when I make a slow speed right turn (making slow right turn at red light, in parking lots, etc) on accleration and turning right at the same time I get what seems to be a grinding feeling from either the steering wheel or the front end somewhere. driving me nuts!
I am assuming by lower steering bearing you mean at the steering box?
I too have had this bearing replaced....in my case, the intermediate shaft was replaced and I then got a creaking/snapping/rattle noise from the underdash space. I spent some time and found that it was the green plastic bearing at the bottom of the shaft making the noise where it was in contact with the steel outer column (the steering shaft would flex/move just enough to make the plastic bearing creak). The shop was finally able to reproduce the noise and replaced that bearing...noise gone.
bbwb
  • 2 years later...
I had that same goose groan rubbing sound and feeling that seemed to come from right behind the steering wheel in my 05 Z71 Crew 5.3L with 165,000km.
Here's what didn't help - greasing the ISS/replacing the column bearing with a green one/taking apart the steering wheel and shooting white grease into the top bearing area/replacing half of the power steering fluid... although the last one cured most of the power steering pump squealing it had.
I even ordered a new ISS yesterday as the next step; however, today at noon I had the local Minute Lube guys lube up everything in the front end - immediately afterwards I noticed that the dreaded goose groan moan rubbing was gone. I tried to get it back but can't, I let it sit for hours and tried again when it was cool - still can't get it to do it one little bit! You might want to get out your grease guns before doing anything else... also, after reading so many posts about dealers replacing different things to get rid of the problem (like changing out steering boxes and pumps etc. I wonder if they didn't (at the same time) lube the front end real good and that's what actually corrected the problem. Just a thought.
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
