Burned Out Hvac Lights
It's true that the lights are attached to the circuit board. But I remember seeing somewhere where someone replaced the stock lights with LED's. They had instructions and pictures. I can't find the thread right now, but some searching should find it.
I had to replace some bulbs in my radio. I got replacements at Radio Shack and soldered them in. It wasn't all that hard.
  • 7 months later...
  • 11 months later...
i did all the bulbs in my trucks dash except for the hvac. i have the manual control w/ 2 knobs (1 fan control/ 1 where the air goes) and 2 sliders(driver temp/pass temp). anybody have any tips on taking this apart i already broke one and the new part is on the way to replace it. but i would like to figure out how to get the old one apart so i dont break the new one!
thanks!
I too am interested in replacing some of the burnt out lights behind my HVAC controls and also a few behind my radio buttons. I can solder pretty well so I am interested in doing this. Have a part number for the bulbs that you guys used from Radio Shack? Also, I have had the radio out of the dash before but how do I get at the bulbs? Fairly simple procedure? Thanks. Also, the link that was posted a few posts up is not working for me for some reason. Keeps coming back saying there was an internal error. Thanks for any advice!
Gentlemen,
I got mine from ebay and they were perfect. Hardest part was unsoldering old bulbs leaving the holes open. Once you figure that out (solder wick from radio shack) the job is really quite easy. RS has bulbs but are very expensive.
Ken
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
