Getting Ready To Tow 5000lbs
i just bought an 08 crew cab 4x4 LT2 with the Z71 package and 18'' wheels on tuesday. i love the truck, but it's missing the tow package, so i basically have to piece that together. i'm hauling my ~2250lb car hauler and 2100lb race car about 200 miles in two weeks, and i need to get the truck ready.
i put splash guards on yesterday, and i need to go get a hitch this week along with a brake controller as my 18' H&H car hauler has dual axle electric brakes. i know i'm probably going to get the tekonsha prodigy brake controller, but what do i need as far as wiring harnesses both to the controller and to the 7-pin connector on the bumper?
any suggestions on hitches? i've done some searching for a draw-tite, but it looks like they can only handle 6000lbs without weight distribution, and i like to have a little more wiggle room than that just in case i load up something bigger than my 2100lb miata race car. :thumbs: putnam doesn't seem to make anything for my application.
anyone installed a hitch themselves? it can't be hard if there are already holes predrilled where they need to be. i've built engines and transmissions before, so i'm pretty mechanically inclined if i need to take some stuff apart first.
i'm holding off on the transmission cooler for now. according to some GM engineers, the transmission doesn't need it, but people insist on having it, so they offer it as part of the tow package. i plan on keeping a close eye on the temps.
thanks.
Why don't you get the GM accessory hitch pkg?...It will give you what you need.
Also...The harness for the brake controller is already under the dash,and the GM hitch pkg. gives you the 7-way connector receptacle w/door that goes in the bumper to plug the trailer harness into.
based on past reports of hitch failures, and because the OEM hitch attaches to the bumper also, i think there's probably better ones out there. as typical, if you know where to look, aftermarket stuff is better and cheaper than OEM. OEM is only rated for 5k lbs right? if i put a regular size sedan on my trailer i'd be over that by a good bit.
after some more searching, i found this one from draw-tite that should be much more than i need, which i like. :thumbs:
http://www.etrailer.com/pc-H~41937.htm?vehicleid=20089906
valid concern, but they got thier shit together on the new hitches...I tow 6500#
I would get the tranny cooler installed sooner then later, and make sure the cooler is rated for the GCVWR. Good idea for the Prodigy, highly recommended. As far as a hitch, I would recommend the a class 4 or 5. Since you are going to put out some coin for a hitch, may as well as get a strong one. And ensure that it bolts right to the frame as opposed to the frame and the rear bumper like the OEM hitch. Shame that Putnam does not make one for your truck. Did you call them and ask? Their web site does not have my truck on it, but they do carry one for it. The Putnam XDR is the way to go. I would call and check.
There are other options such as a HD alternator and air filter, but it seems like you got it all, or at least have the information to tow safely.
Doesn't the OEM become a class V with a WD?
yes
i was the same way on the tranny cooler at first. i called my friend who is the parts manager at superior chevrolet, who supplies all the parts to the Phoenix guys down in florida if you're familiar with the road racing scene, and is also a hendrick dealer. he said that when he went out for training on the new trucks, the GM engineers that were there told them that the truck doesn't need a cooler, but that everyone thinks it's a must, so they offer it. i'm pulling <100miles each way, so i'll just keep an eye on it for now.
i'm trying to find a hitch with about an 8000lb capacity without the weight distribution. i can find lots of 6000, and a few 10,000 but that's about it. given the choice, i'll probably spend the extra $50 and get the 10,000lb one which is probably a class IV or V. i didn't call putnam, i just checked their site. but if they make one for yours, i'd bet they have one for mine also. what did the XDR cost you?
I paid a lot more then you would if you are in the US. I cannot recall the price, but it at least 1/3 what I paid. I paid $450.00 Cdn for it, but it is worth it.
When i switched from the OEM to the Putnam, the truck and trailer performed as one unit. Even with the WDH, you can tell there was a trailer there by the bounce because the OEM hitch 's first point of contact is where it is bolted to the bumper. The WDH cannot do its job. The Putnam is bolted to the hitch, so any bounce fron the trailer is transmitted and absorbed by the truck frame. It is almost like the OEM hitch was flexing and due to the round tube (Putnam is square tube) and it made for an uncomfortable tow.
Air bags are a good addition. Takes the hobby horse feeling and really stabilizes the ride.
i looked at the XDR and i think that would be COMPLETE overkill. however, the putnam class IV looks like a pretty good option. i can't find anyone that carries it though, any suggestions?
When I bought my 2000lb steel open deck trailer to haul my 87 Vette, I had to look around for a good 2" hitch ball. The trailer had a Bulldog hitch and it's designed for a 2" ball. Most balls are stamped with a 5000 lb rating but I did find one rated for 6000lb.
Most slugs are also rated at 5000 lb but many trailer and RV places will have ones rated for higher towing capacity.
The tranny cooler is a good idea. Get one that is a "stacked plate" design as they will provide better cooling for the size compared to a tube design.
I just installed a pair of Air-Lift air bags on my 99 Silverado Z71. Their primary purpose is to keep the truck and trailer level and not increase the weight carrying capacity like overload springs will. I only need about 15-20 psi in them to level the truck and trailer.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
