1994 C2500 No Spark Or Start
Hello. I have a 1994 c2500 and I seem to have an intermittent starting problem. I can drive it, and as soon as I get back, let it sit, for 30 min at least, try to start, ad it just cranks.
I've got a good cap, plugs, coil and wires. I got to thinking and every once in a while my blower, or my hazards don't work either. I'm not sure what else to check, or where to go from here, but tomm, I'll be able to start it right up.
Thanks for any help guys.
Jeff
Oh, and it has a 350 in it, and good fuel filter. Also, i can hear the pump run, and if I add fuel to the carb, during the no start, nothing happening. Thanks
I remember some posts about bad ignition switches in those trucks. I had a similar no start issue in a Chevy Blazer that turned out to be the ig switch too. Worth a look.
Would the Ignition switch cause crank, but no spark?
Thanks for the speedy reply. You're worth a million
