2003 Suburban Brakes Pulsing
chevsuz12
Hi, my 03 suburbans brakes are intermittantly pulsing, but only after slowing and near a complete stop then pulse. The initial brake bite and feel is excellent. But when almost stopped they pulse for a second or so then work fine.
I since checked the front brakes discs and rotors look great, and are original with 40,000 miles.
I checked the rear, they were worn pretty bad, I replaced discs and rotors. The pulses still continue. Could this be a sensor issue?
Any help is appreciated.
Thanks.
Front rotors need to be turned. They are slightly warped. Very common problem after many many heat and cool cycles on disc brake vehicles. Should be a really easy fix.
Could be Jim but I think he might be describing an abs activation as a pulsation. There is a bulliten on unwanted low speed abs activation and it's pretty common. We are currently on bulliten posting lock down but I'm sure you can find a copy if you are a good with a search.
Guys, thanks for your help. Found the bulletin, pulled out all wheel sensors and they all looked like new. No corrosion at all. The things I have done to attempt to resolve this problem are the following:
Replaced rear rotors and pads.
Inspected front rotors and pads (have some wear but not bad, and pads have a lot of life left.)
Inspected wheel sensors.
Yesterday, it finally caused another problem, after weeks of the pulsing while coming to a stop, the pedal went to the floor and the system displayed "SERVICE BRAKE SYSTEM" also displayed ABS, and BRAKE idiot lights.
I don't want to go replacing everything until I find the problem, but not sure what else to do. I am thinking of replacing front brake rotors and pads next. For the time being I pulled the Brake Fuse, the pulsing stopped.
Any other opinions?
Thanks.
HELP! :lol::D:tear::P:D:sigh:
Now I have changed front and rear rotors and pads, and of course the ABS is still activating. The brakes feel excellent, as it is about to come to a complete stop the brakes pulse. Feels as if ABS is falsely activating.
If I pull the brake fuse, problem goes away. So if all brakes are replaced, then what could the problem be?
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :sigh:
My best guess is your going to need to replace the sensors. There isn't a good way of telling without some testing. I couldn't begin to tell you how to do that at home.
IMO, that's what sucks about all this new technology,(sensors,etc), the life of the backyard wrench monkey is pretty much non-existant. :lol:
Had a similiar problem with a Dodge.  All the ABS sensors were ok, but the exciter ring was cracked which gave two teeth on the ring a wider than normal gap.  This would activate the ABS on that wheel when the vehicle slowed to below 10mph.  Had to replace the hub on that one.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
