changed my oil
Like most of you, I change my oil every 3000. I did my second oil change yesterday on my truck ( in sig ). No problems except I had to use my jack on one side of the truck to level / raise it so most of the oil would drain. Here's the weird part:
I check my oil level on a semi regular basis, never shows any oil consumption on the dipstick. I use 5 qts Mobil 1 5w30 and a PureOne filter. After I filled yesterday, the dipstick showed overfilled  ??? ...not worried about that, I haven't taken it for a ride yet. I drained the used oil back into the empty qts and I could only fill 3 1/4 qts!! Where did the other qt 1/2 go? Can it still be in my engine? There was still some in the filter, but not that much.
Anyone have any ideas?
There will of course be SOME oil in the engine, but hardly.
You say you showed over-fill on the dip-stick, thats the way i keep track of my oil, not the "full" line.
So, my guess it that you did use up some oil, which is normal.
As long as your not experiencing the oil consumption that others are reporting :)
I guess I'll have to keep a closer eye on things. I just can't imagine using that much oil, nor leaving it behind in the engine/ drain pan.
Some filters incorporate an anti-drainback valve into the design.  It prevents oil from draining back into the crankcase during engine shutdown and is supposed to eliminate dry starts.
I think the Pure One has this and may be responsible for your misreadings on the dipstick.
Run it and then check it.  You have yet to let the oil circulate through the entire oiling system which includes the filter.  This will drop the fill line down closer to the full line on the dipstick.
I have always checked for leaks and oil level after the change and after running it for a couple minutes. I'm going to check it today, I've got about 65 miles into the oil change now, I'll see if there is any drop in the level.
Thanks
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
