Need Gm Part Number For Evap Vent Valve
JA_Silverado_04
My truck is throwing a P0449 and I'm looking to replace the Vent Valve Solenoid.Can someone give me the GM part number for just the plain Evap Canister Vent Valve Solenoid? I can't find it anywhere.I have a 2004 2WD Silverado Reg Cab Long Bed w/4.3L (LU3).I'd prefer not to do the Vent Valve Kit - I don't drive off road and I don't seem to be throwing a P0446 that the TSB calls out.Can someone help me out?Thanks.- Joe
Thanks for the quick reply.Well, maybe that would explain why I couldn't find it! The funny thing is, the only reason I could find the part number for the Vent Valve Kit was because I saw it mentioned in the TSB [ 02-06-04-037 ] and other places here on the message boards.You would think they would list the old part number and reference the new one so that you know its obsoleted.
  • 2 months later...
Hopefully someone can help.
Based on the TSB I ordered Vent Valve Kit P/N:19152349 for a 2004 or later Silverado. However, when I went to install my kit, I came to the conclusion that I had the wrong part. It was impossible to mount the Vent Valve on the existing due to clearance issues in both the front and the back.
My Vent Valve is over the front of the gas tank like - is it possible that I need the 2003 and earlier kit?
  • 5 months later...
Did you ever resolve this problem? I'm in the same spot with a 2004 silverado extended cab 4.3L, but I haven't ordered anything yet.
I'm still in the same boat. I went to the dealer to pick up another part this morning and I inquired again about the part and they mentioned the same part again and didn't know anything about the possibility of needing an '03 part.
The key is my Vent Valve looks like its the '03 configuration from the TSB. The vent valve is over the front of the gas tank right between the cab and the bed. I believe that the '03 kit comes with a new bracket that changes the orientation and replacement hard fuel vent hose clips both of which it seems I need.
I may be forced to just order the '03 part to try it out.
Check this thread for images of where the Evap Vent Valve is located. Mine is in the 2B location.
http://www.gm-trucks.com/forums/index.php?...ic=83753&hl=
I just put the 2003 kit in my 2004 Silverado. It is the correct kit. The ACDelco part number is 2142081. Install is pretty easy, once the old valve assembly is removed. The new valve includes a 6-8 inch electrical extension that was plenty long enough. It also includes a new pipe to the evap cannister, with 2 clips, and a new mounting bracket. The only funny thing is that the new valve's connection to the filter box ends up pointing the wrong way: toward the rear. But the 5/8" hose that I used could be easily curved around to point toward the transmission. The key to all this is to figure out which kit to order for the specific truck that needs fixing. If you look down between the cab and bed, and see a shiny black plastic pipe, about 3/4" O.D. secured with two black plastic clips, then you need the 2003 kit.
  • 3 months later...
I'm curious to know if this ACDelco 2142081 part fixed the check engine light/P0449 (my first 3 times, it was P0449, the last time it was P0455). My 2003 Chevy Z71 extended cab (5.3L, 120,000 miles) just started doing this (P0449). My first attempt to fix, I pulled the evap vent solenoid from the top of the front of my tank between the cab and bed, then disassembled, cleaned, sealed, and put back in. No code/light for about 2 days, then it came back on (P0449). Bought a new fuel cap from the dealer, no code/light for 4 days, then the light comes back on today (P0455). Do I need the ACDelco 2142081 part? Should this fix it? Does this part relocated the solenoid? Do I also need to replace my vapor canister? It is in front of the tank now. Will I need to relocate it to the side of the tank? Thank you for the help.
I put part 2142081 (from Rockauto) on my early 2004 Silverado 4.3L extended cab. I had code P0449. Fixed it perfectly. Reset computer. Code gone permanently. My old vent solenoid had no electrical continuity when I tested it. Coil was open. The computer senses this and throws code P0449. Test it before you replace it.
Just to add to this topic, I've been troubled by this code for a few months, on a 03 5.3L Silverado. When I found that the GM replacement was a remote 2 piece kit that my dealer quoted me at $190.+, I decided to go with the thread I read recently about the 06 Suburban Vent Valve Solenoid was the exact same part as the original, only costing around $30. at the GM parts counter. After going yesterday and picking this up, I went home and wrestled the old one off my truck, kinda hard to release the large hose with the tight room where the valves' located at. BUT, when I put the old one next to the new one, the small vent tank on the NEW one is larger, and round, compared to the smaller, oval tank on the original. I tried to see if the new would fit at the same location, but not enough room. SO,O,O,O, I lifted the small plastic tab on top of the solenoid that released the tank, and rotated the solenoid which about a third of a turn, comes out of the tank. I took the new one apart same way, and saw that the nozzle of the new solenoid was about a 1/2" longer, and slightly bigger around. I measured this from the old one, cut off the new one at the "ring" which had 2 tabs that fit into the tank to lock it on. I then used a high-speed 1/8" air grinder to taper the larger, round nozzle down to the smaller diameter where the "O" ring sits close to the body of the solenoid, except for 2 tabs I left at approximately the same location as on the old solenoid. Fit it in the old, oval tank, and replaced it on the truck, no code now!
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
