Brakes
excaliboar
'99 GMC Sierra Ext Cab Z71 new body style.
How hot should my rotors get while normal driving? I noticed the other day I could smell my brakes when I parked in the garage. Got me worried that I have a brake hanging up or dragging, but it doesn't pull or feel like it's dragging. Local mechanic said wheels rotate freely and not to worry.
excaliboar,
how many miles on your truck?
when I first had mine ('00 ECSB 5.3l 2wd), a rear pad was found to have dragged occasionally as I found that it was the only pad worn down almost to the metal backing. All the other pads seemed to be almost new and this was around 50-60k miles. Otherwise I can get a set to last almost 100K :lol:
They will get hot if you do any braking. Did you recently get new pads? When I changed them out the first time I got the cheaper set from A-zone, and they were pretty stinky as well as noisier (more squeal/screech) than the stock ones or the better aftermarket ones.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
