Truck Goes Under The Knife Next Monday
Well guys, my truck goes under the knife Monday. Got a little problem with the transmission. 1-2 shifts great, 2-3 not so good, the rest is good. What iam having done it getting the truck re-geared(3.73 to 4.10). B&M trans shift kit. Mag-Tec diff cover. Getting all the fluids changed to royal purple. Then he going to tune it with the SuperChips programmer to get everything right again. All this is costing me a pretty penny ($1700). I will keep ya'll updated, supposed to be in there for 3 days :dunno: , Got to drive my mom's trailblazer. Lets all hope for the best for Big Red.
Im sure it will be well worth the time and money spent.
I agree. Not much but good can come from those mods.
Yea everything should come out ok, iam also putting headers on it, probably slp, and then he talked me into a throttle body spacer...i know there are like 3o threads on those, but i dont give a damn...lol. Thanks for your thoughts guys. Love your truck btw Matt....one of the best looking gmt-900's ive seen.
Yes
Yes
Mag-Tec diff cover.
Yes
Yes
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO. (unless he's tuning it for free, but even then it should be free).
Sweet! Trucks going to be a beast Justin! Sounds like you have a great plan. It should be money well spent. Good luck and keep us updated! If possible post some pictures.
Oh....and if you maybe have a little extra money feel free to "upgrade" my truck too! :dunno:
Thanks man....ill send you some. BTW, i didnt have any luck finding signal mirrors for your burb. Come to think of it i've never seen them on a 97'. I think iam also gonna do cold air intake.....lol!!!
Sweet. Yeah the only signal mirrors I have seen are kits. No OEM stuff. Ow well, someday I pick a kit up.
A cold air intake woud be a nice addition, and might as well do it all at once. Check out that SLP post. They look like they have some good stuff for your truck.
yea i saw that, their prices are crazy, even on sale. I dont have any hookup's through them like i do k&n or any other guys
You dont have to use SLP. Tons of companes make CAI's for your truck. K&N is a good company, I have never had any problems using there kits. Find one you like and can afford, and go for it.
Well guys the beast comes out at 5:00 PM central time today!!!! They sasid at the shop its a whole new monster!!!!
btw....didnt put the cia....i already have kn drop in filter with the hd cleaning thingy....
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
