Cranked T Bars Now Problems
Hello, I have read many posts and searched however I did not com across an issue like this. I installed 2" blocks in the rear and cranked my tbars 1.5 inches. Now this morning on the way to work I have developed a front end wobble of some sort at certain speeds. Is this because now the camber/caster angles are off and will this remedy itself when I get my alignment ? Thanks, Jimmy
You could have lost a wheel weight. :thumbs:
When you take the truck in for alignment, have them check the balance of the wheels/tires.
How long have you had them cranked for?
I think with 1.5 inch cranking, you may need an alignment.
