4hi Binds
yank8200
When I am driving in 4HI and due a full turn at slow speeds the front end fights the back end causing the truck to lock up. It is a NBS 07 and I tried the same test last year and did not have this issue now I do. Is this normal for front tires to fight the back tires? I don't have a locking diff.
Is this on dry pavement?
If so, it's completely normal. When turning, the front and rear wheels need to rotate at different speeds, and when locked in 4wd, the transfer case doesn't allow them to rotate at different speeds, hence the locking. Only use 4wd in situations that would allow the wheels to slip (on wet/snowy roads, gravel, dirt, etc).
Yes, its normal, interesting you did not notice it last year. Only explanation I have is eithe the hubs did not engage, the front differential did not engage or the transfer case did not engage. Or, the ground was slippery nough so as not to cause the binding. As mentioned above using the 4 wheel drive system on dry pavement lowers fuel economy and is not condusive to the good health and longevity of the 4 wheel drive system.
The hubs are never disengaged, the CV axle gets bolted right into the splines of the hub. It's the front diff, and T-case that do the engaging/disengaging. (IE the CV axles are always spinning when the truck is in motion).
Not unless the traction is really poor to warrant the need of additional traction. Otherwise you're wasting gas. The owners manual has some good suggestions for the use of 4 wheel drive.
Yes, yes, my bad. Too much thinking out loud.
Unless you are in a low-traction situation (snow, ice, off-road, etc.) there is no need for 4wd. Using 4wd on dry pavement will only decrease fuel economy, and increase wear on the front drive train and front tires.
It's all good. :dunno:
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
