Brakes
teddyv2
I have a 2000 Suburban 1500. I thought I was having a rearend bearing failure until I pulled my left rear e-brake and found it disconnected at the backing plate. Apparently the park brake actuator lever fell out of the adjuster and off the e-cable. The retainer wasn't anywhere to be found inside the disc either, so nothing was holding it from rubbing inside the disc. I pulled ebrake out and I still have to disconnect and pull the other side.
Any reason why the actuator lever would just fall off? Thanks.
    mighty K20
    mighty K20
  • Who's Online   2 Members, 0 Anonymous, 554 Guests (See full list)
