BigC Posted November 11, 2008 Posted November 11, 2008 So as to limit the amount of flamming I'm sure to receive, I've read through the posts and used the search function. I have a 02 Sierra 4wd Z71 and I will be changing the diff fluids, both front and rear and the t-case. I've read many different opinions on which fluid to use, and will more then likely stick to dino in the front, and synth in the rear. I'm leaning more toward the Royal Purple but will take any suggestions. As for the actual process, all three fluids seem rather easy to change, but I'm just confirming that the guides listed in the tech wiki, will apply to my truck? Also, by using the hex key method for filling, can someone give me an idea of how much rear fluid to fill and will this same method apply to the front diff? Lastly, how much should i fill the front t-case? (capacity numbers are welcome, but seeing how much this topic was covered, i wont belabor the issue) and now lastly...really...my truck has 63K on the odometer...so its time. Thanks in advance! C
merlin5577 Posted November 11, 2008 Posted November 11, 2008 Flamming? Here? NEVER! If your going through the trouble of changing all the fluids, I would put synthetic in both the front and rear, and use the GM stuff in the transfer case. With all three, just fill them to withing 1/4-1/8 inch of the fill plug and seal them up. After a few hundred miles, pull the fill plugs and check the levels. The front axle I believe is 2 quarts, the transfer case is another 2, and the rear is 2+1/2 to 3 quarts IIRC. I use Royal Purple in both my trucks axles and love it! Smooth operation and very quiet. But like I said previously, IMHO use the GM stuff in the transfer case. Good luck, and keep us posted.
C & A s Dad Posted November 11, 2008 Posted November 11, 2008 Specs from Valvoline T Case holds 4 pts Front diff 8.25 gear holds 3.6 Pts From diff 9.25 gear holds 4.9 Pts Rear diff 8.6 gear holds 5.5 Pts Rear diff 9.7 gear hold 5.9 Pts They use a disclaimer that says all capacities are approx and you should still check the level. You have likely already read this, but be sure you pull your fill plugs before removing the covers. I used Amsoil's Severe Duty 75W 90 but I am sure RP offers a very good similar product.
travisstorma Posted November 11, 2008 Posted November 11, 2008 Specs from Valvoline T Case holds 4 pts Front diff 8.25 gear holds 3.6 Pts From diff 9.25 gear holds 4.9 Pts Rear diff 8.6 gear holds 5.5 Pts Rear diff 9.7 gear hold 5.9 Pts They use a disclaimer that says all capacities are approx and you should still check the level. You have likely already read this, but be sure you pull your fill plugs before removing the covers. I used Amsoil's Severe Duty 75W 90 but I am sure RP offers a very good similar product. I think the mood as of lately is for people to change their fluids. I've been planning to change mine in a week or so. I have also been wondering what the capacities the front / readend are. As long as this is close for the 04 1500's then I think I should be good to go! Thanks for the info.
merlin5577 Posted November 11, 2008 Posted November 11, 2008 Specs from Valvoline T Case holds 4 pts Front diff 8.25 gear holds 3.6 Pts From diff 9.25 gear holds 4.9 Pts Rear diff 8.6 gear holds 5.5 Pts Rear diff 9.7 gear hold 5.9 Pts They use a disclaimer that says all capacities are approx and you should still check the level. You have likely already read this, but be sure you pull your fill plugs before removing the covers. I used Amsoil's Severe Duty 75W 90 but I am sure RP offers a very good similar product. Thanks for the specifics.
merlin5577 Posted November 11, 2008 Posted November 11, 2008 Specs from Valvoline T Case holds 4 pts Front diff 8.25 gear holds 3.6 Pts From diff 9.25 gear holds 4.9 Pts Rear diff 8.6 gear holds 5.5 Pts Rear diff 9.7 gear hold 5.9 Pts They use a disclaimer that says all capacities are approx and you should still check the level. You have likely already read this, but be sure you pull your fill plugs before removing the covers. I used Amsoil's Severe Duty 75W 90 but I am sure RP offers a very good similar product. I think the mood as of lately is for people to change their fluids. I've been planning to change mine in a week or so. I have also been wondering what the capacities the front / readend are. As long as this is close for the 04 1500's then I think I should be good to go! Thanks for the info. Better get a move on, its going to get cold soon.
BigC Posted November 12, 2008 Author Posted November 12, 2008 Thanks for the info folks....I'm probably going to dive into them this weekend. I'll keep ya posted.
travisstorma Posted November 13, 2008 Posted November 13, 2008 Since you guys know more about this then I do I just want to make sure I got the right stuff that will work. I have a 2004 Silverado 4x4. I just bought some Mobile 1 Synthetic 75W - 90. I remember reading that the fluid I get should meet API GL-5 which this fluid does. This stuff work or should I take it back? Thanks! Travis
merlin5577 Posted November 13, 2008 Posted November 13, 2008 Since you guys know more about this then I do I just want to make sure I got the right stuff that will work. I have a 2004 Silverado 4x4. I just bought some Mobile 1 Synthetic 75W - 90. I remember reading that the fluid I get should meet API GL-5 which this fluid does. This stuff work or should I take it back? Thanks! Travis Yes sir, good to go.
merlin5577 Posted November 13, 2008 Posted November 13, 2008 Since you guys know more about this then I do I just want to make sure I got the right stuff that will work. I have a 2004 Silverado 4x4. I just bought some Mobile 1 Synthetic 75W - 90. I remember reading that the fluid I get should meet API GL-5 which this fluid does. This stuff work or should I take it back? Thanks! Travis Travis, I noticed you only have 2 posts, you should check out the new member section and do an intro thread.
travisstorma Posted November 13, 2008 Posted November 13, 2008 Thanks for the info! Since you guys know more about this then I do I just want to make sure I got the right stuff that will work. I have a 2004 Silverado 4x4. I just bought some Mobile 1 Synthetic 75W - 90. I remember reading that the fluid I get should meet API GL-5 which this fluid does. This stuff work or should I take it back? Thanks! Travis Travis, I noticed you only have 2 posts, you should check out the new member section and do an intro thread. Sure thing.
