Jackson76 Posted December 6, 2008 Posted December 6, 2008 hi guys!!! does anyone knows if the 2500 rear axle fit on the 1500? what else will i have to change? would i have problems with the transmission? what would be the added benefits of this change? thanks
Draenor Posted December 6, 2008 Posted December 6, 2008 If you change the back, you will need to swap the front to match the new lug pattern. As for benefits, there would be none if this can be done.
alwcurlz Posted December 6, 2008 Posted December 6, 2008 hi guys!!! does anyone knows if the 2500 rear axle fit on the 1500? what else will i have to change? would i have problems with the transmission? what would be the added benefits of this change? thanks What is the intended purpose of doing this?
Jackson76 Posted December 6, 2008 Author Posted December 6, 2008 i dont have a specific purpose. but if i have to that would be lot of offroad
Zembonez Posted December 6, 2008 Posted December 6, 2008 The 1500 axle is more than tough enough for the job. You'd be much better off upgrading shocks and maybe springs if you plan on doing a lot of offroad driving. Swapping the axle won't give you any advantage. The 2500 axle is just designed for more weight carrying capacity... but it takes more than just swapping it out to make a truck a 2500.
Jackson76 Posted December 6, 2008 Author Posted December 6, 2008 ok thanks a lot for the info. so guess i better upgrade the leaf springs for a pair of 6" deaver´s
