Louie,
I'm in North Florida. Let me know if I can help, if we can ship to a business address it will be significantly cheaper.
Trav_13,
The only wiring was done at the floor harness/30pin seat connectors on each side. All the communications are done via GMLAN, so the wiring in the doors stays the same. I'm doing the writeup now... flashing was kind of a trial and error session... but what works is using a 2009 VIN from a _non-cadillac_ vehicle that has KB6 seats (Can't use cadillac calibrations because the seats are operated by the HVAC controls on the dash, not by door switches). The door window switches and the new MSM have to flashed.
Richard
I'm pretty sure that charcoal and ebony are the color.
If your truck has the AN3 option code, it should be prewired for these seats.
The memory seat module (under the drivers seat) controls all the power/lumbar/heat/memory functions. Making all the functions work requires that you have power windows, the memory/heat seat switch(drivers side) and heated seat switch (passenger side) installed into your door panels, and possibly some programming at the dealership.
If you dont care about making the memory seat recall or heated seat portion work, wiring for the just the power adjustable seat/lumbar is quite simple, just a few hot wires and grounds. Everything for the power movement/lumbar is self contained in the seats.
$900 for both front seats, plus freight. They are basically brand new seats, complete with the memory seat module and all wiring on both sides. I have a purpose-built shipping pallet for them.
I will do a write up on the heated/cooled seat (KB6) install this week and get it posted as soon as possible. I appreciate all the interest.
Richard
stick it into the Tech Wiki
thanks Richard....I'll check my codes, as for freight, what part of the country are you in?
Louie
http://www.gm-trucks.com/forums/index.php?...icle&id=759
I added the writeup to the Tech Wiki. I have not had time to create a wiring diagram yet, will try to do that this week.
Feedback is appreciated.
Richard
Louie,
Trav_13,
Richard
Richard
Louie
Richard
my truck doesn't have the AN3 code...if I understand you correctly, I could still get the power movement/lumbar by just getting power to the seat? ...are there 2 versions of the lumbar movement?.. can you enlighten me on that and tell me which version your's is?
thanks
08Z,
I think LT2 trucks have a different door panel configuration, with the door handle itself located underneath the door arm rest. The power window switches are a different shape, though they might be the same electronically - I simply do not have a way of knowing. Best case, if the switches are the same, you'd have to create a spot within about 9 inches of the power window switches to mount the heated/cooled seat switch (thats how long the pigtails are that plug them into the door window switches). Then you'd bolt the seats in, and have to make the the memory seat module wired into the GMLAN network properly... I'm not saying its impossible, but it would involve a little bit more fabrication than a truck that already had LTZ interior. Alternatively, you could purchase new door panels, and essentially upgrade your interior to LTZ. Then everything would fit where it needs to.
what if you just have the LT2 option with power adjust? What all would be involved here?
GoldBourbon,
There are 3 different power seats (that I know of) that came in our trucks.
The first is the LT2-style 6 way power adjustable seat. It can move back and forth, and move the front or rear of the seat cushion up or down. Seat back recline and lumbar are manual.
The second is the LTZ style seat, which features 12 way power adjustments - back and forth, seat cushion front and rear up and down, seat back power recline, lumbar in and out, and lumbar up and down. The seats I have seen with these features usually are heated also.
My old seats are of this design - charcoal leather, 12 way power, and heated w memory recall.
The third seat is the full KB6-optioned heated and cooled seats, they have all the features of the previous model but also the active heating and cooling systems.
If you have a fused 12v source, and a ground, I believe you can have all the power and lumbar features in the seats operational. Accordingly, I will bench test the seats I already have out of my truck to make sure this is the case and let you know for sure.
Edited by rich22
"If you have a fused 12v source, and a ground, I believe you can have all the power and lumbar features in the seats operational. Accordingly, I will bench test the seats I already have out of my truck to make sure this is the case and let you know for sure. "
thanks for the seat info Rich...I'm definitley curious if the heat feature could be powered up also but the memory feature's not that important
Louie
It would be possible to wire a toggle switch that would turn on the heated seat elements directly, however, you'd also have to turn them off before they got too hot... one of the things the memory seat module does (in the heated only seats) is monitors the temp of the seating surfaces, and cycles power to the heating elements to maintain the desired level of heat. Making the heat part work like it was designed to from the factory would involve the power window switches being programmed, and the heated seat switch being installed in the door panels. Not impossible... but if you are going that far, you'll get the memory functions anyway, as the driver side heated seat switch also contains the memory seat buttons.
Louie
GoldBourbon,
Bench tested the seats today, only requires a few wires be tied to a 12v always on source, and a good ground. All 12 power movements, including lumbar functions, work in this configuration.
Thanks,
Richard
I'd be interested in a "how to" also...I have black leather in my recently purchased 08 sierra CC, but no heat.
I've been freezing my ass off the past couple of mornings.
Does your truck have memory drivers seat and power windows?
Power yes, memory NO
Is your interior door handle above or below your armrest?
Below....
You'd have to create a spot for the switches... pigtail from the heated switch to the door switch is about is about 1 foot long... 12 pin connector, so it would take a lot of splices to lengthen it, but it could be done if you wanted to mount them somewhere besides the door panel.
If you can, pull your drivers door switch out (should just pop straight up, carefully pry around the edges) and see if there is an empty connection on the bottom of the switch, 2 rows of 6 male pins.
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
