Hey All
sasulfer
I have a 1992 GMC sierra xc sb 4x4. she's been a good truck. I have owned gm products my whole driving carreer. Never had a GM product leave me stranded, they always get me home.
Joined to be of some assistance when possible and to get help when needed.
THanks
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
