Show Your Truck Here
faisal
show your's i dont own a truck 4 now :ughdance:
i want to know whats good whats not :rollin:
no roles...post as many as you want but wright down every thing you have on the truck
mine is a 06 silverado RCSB 4.3L V6 2WD!!! great truck i love it!!!
added wheels and tires, and a tow hitch!
Oops forgot to add the Duplicolor DIY Bed Liner (Crappy Product!!!, Did every thing right and it fades and chips away easily) and RIKENSPORT 9936 HID 6000K Super White HID's!!! Tinted Windows dunno %!!! and bowtie hitch cover!!
You can see my truck in the sig.
It has:
- Diablo Programmer
- Westin Sportsman SS Brush Guard
- GM Accessory Mud FLaps
- Custom Dual Exhaust
- CoverKing Neoprene Seat Covers
- Lund Chrome Bug Guard :ughdance:
- DeeZee Diamond Plate Bed Caps
- Delta Toolbox
- Recon Line of Fire
- Cobra 29 Black Chrome Edition CB
- Nitto Terra Grappler 265/70/17 tires with 17x9 Helo Maxx 6 Wheels
- Line-X Under the Rail Bedliner
- 15% Window Tint
I think thats it.
Visual mods:
LineX-ed Rocker panels
OEM textured fender flares
Westin Bull Bar
Hella 500 series Driving Lights
Chrome Tahoe Grille
Textured black bowtie
Clear Corners
Smoked taillights and third brake light
Extang Soft Tonneau
Smoked bug guard
GM OEM alloy wheels
265/75R16 Mickey Thompson Baja MTZ
De-Badged
1.5" torsion crank
SI/DO Flowmaster 40, 18"x3.5" slash-cut tips
My 2003 silverado LT. See sig for mods.
The 1996. 198,000 miles. Not many mods that i've done...
quick pic with the rims on :ughdance:
thanks guys...great trucks..
:ughdance:
thats ugly man.....no realy it makes the truck ugly
but 4 the other mods :thumpsup:
8000k HIDS, Dual Magnaflow exhaust, Jason hard tonneau cover and 35% tint on the front two windows.
Can be seen in my sig. I don't have much, tust tinted windows (can't remember the exact percentage, I know its legal though), UWS nerf bars, added the DIC, and switched from the 245 General Americrap tires to some 265 Michelin LTX white letter tires. As money permits I'm planning on getting a tune, bed liner, intake, exhaust, remote start, and possibly a steering wheel with audio buttons. I doubt I ever finish though, I'll just keep adding stuff to the list and continue to install as money permits.
Kyle, that's a slick 400, for some reason I've always liked the 400s the best (not to say I don't love my truck though)
Thanks, appreciate it. Which one again is the 400? My 96 right?
Yup.
88-99 classic = GMT400
99-07 classic = GMT800
07+ = GMT900
Much easier than the whole oobs obs nbs nnbs nobs onbs oonnbs etc. :gmc:
Comp cam, intake, exhaust, E-fans, HSW N20 kit, tune, 295 M/T drag radials, and a 4l80E currently getting taken apart. This spring it might have another N20 kit secret.gif
edit: 3000 posts
edit2: 5 wrenches
love the VMAX punmax
nice slikers sam....cam numbers please
IVAN....amaizing color but you need some wheels....17X9 will be hot or 16X9
thanx guys ...keep up the good work....any one wants to update no probs....remember...no ruels
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
