How Many Miles So Far...
Got mine in Sept 2008 w/12 miles.....now has 30331!
thats the nicest oversized load vehical I ever seen, they usually use old s10's or some other POS and they find some retire crossing guard to follow it. :cheers:
I like to ride in style!...My other escort rig is a 06 Ford Ranger but it isnt beat up either.I like to keep my trucks looking good,thanks for the comps!
  • Replies 142
I bought mine new on May 31, 2007. I forget how many miles she had on her at the time, but she rolled over 21,300 last night.
Considering the first year I owned the truck, I lived less than 2 miles from work and I now work from home, that's not too bad... But, I do like to take road trips. So, I tend to get miles in big chunks.
Someone mentioned OnStar earlier... I just checked my vehicle history info on there. Between 5/31/07 and 7/30/07, I racked up over 4600 miles. Most months, OnStar says I average somewhere between 20 and 30 miles per day (which seems crazy to me, since the truck is parked most days - but I digress). One month this year, I averaged 109 miles per day. So, like I said, it comes in big chunks. :cheers:
Depending on the weather (and me getting rid of this damn cold), I may rack up another 2-3k between Christmas and New Years.
Bought it on May 8, 2008 with 3 miles on it. It now has 4,200 miles.
Well, when I originally bought the Denali, it had almost 7k on it. Then traded it in with 24k almost exactly 2 years later. So, yeah, I definately didn't drive it all that much! Living 8 miles from work does help though. :cheers:
I haven't had the CTS very long, but I've already been driving it quite a bit more than the yukon. I don't exactly go out of my way to keep the miles off, that's just how it usually works out. We'll see how it goes!
Hey Leo are those ATS trucks in your signature photo?
Ace Transportation
How do you get a job driving with just the Wide load sign on your truck? Seriously i'm out of a job right now and that is something i could do all day with no problem
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
