Re-gearing Rear End For 35" Tires...
hey it's me, the newbie donkey, lol. i was just curious as to how you re-gear for bigger tires. is it done by just plugging in a chip or is it actual mechanic business? thanks for the help...
There are a couple ways of doing it.. You can go to the dealer and they can re-flash your pcu for bigger tires
-or-
*You can get some type of performance tune like a hand held device or PCU tune... IMO I would go for a blackbear or wait4meperformance tune...
Another thing to keep in mind those 35" will take a toll on that 10 bolt over time... IMO I wouldnt go over 33 but to each his own...
just my opinion but don't go with wait4me. Nelson Performance and Blackbear are the go to people. Justin at blackbear has a great rep on here
His is a 4x4 so he needs front and rear new ring and pinion gears at the very least.
Probably has 3.42 or 3.73 gears now. Might want 4.10s. If these numbers don't mean anything to you... then you need to seek out the help of a professional shop.
Welcome to the ZOO!
Welcome to the ZOO!
-1 :lol:
thanks everybody, one of my buddys said i should go with a 3/4 ton rear end. i thought he was joking but looks like he might be right? i will check up on that blackbear and see what's the haps on that. thanks again...
for 35's you should be running 4.10's or 4.56's. your 8.5" 10 bolt will be fine as long as you don't beat the hell out of it. i put plenty of miles on my '05 with 35's and a 10 bolt rear with the stock G80
Yeah the light duty 10-bolt will be fine with 35's unless you are beating the truck up. The g80 is the weakest link in there now. Re-gearing involves actually installing new gears. I would got with a 4.56 at the least. Also if you would feel more comfortable, try searching for a 14-bolt rear from a Vmax. I am STILL searching....
you should have just BOUGHT the v-max lol
Yeah, I know. I had a brain fart 10 months ago. I wanted one, but didn't think I would be lifting so said screw it. Now, I should of known I would get the itch again as I have lifted my last 2 trucks. Just wasn't thinking and wanted a new truck that day! Oh well.....
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
