Who Makes the Nerf Bars that..
The simply run parallel to the body and are "open" on both ends.
Thanks
I have the Westin Oval tube steps on pre-order right now.  I was told I should expect them in April sometime...   :)
I like!  I think it was in the Summit Racing catalog, that I saw a company that makes billet inserts to replace the black plastic steps on the Westin and Smitty Built nerfs.
When you get them on the truck, I will look forward to pics.  Wonder if Paco would give it a single or double bling?
  • 1 month later...
I spoke with Westin last week and they said they will begin shipping the bars later in the week.  They said they will ship them in the order that they recieved orders.  I ordered mine in March so I'm guessing I should get them fairly soon.
It's really taken them quite awhile to get these new bars in production.  They first released pics of them last November!!!  I've been trying to be very patient because I really would like to have these bars on my truck.  The idea of a 6" oval sounds like it should give better protection than a standard "nerf".
I'll post pics as soon I get them and install them...
Aluminum can't rust and they have a lifetime guarantee. Those two selling points attracted me.
You are correct, but they are chrome plated....that CAN rust.  If you don't believe me, take a look at my bumpers.  Luckily they do say the coating is guaranteed as well
I'll take stainless anyday.
lol-I guess I should have been more specific. I want the black powdercoat to go with a white truck.  I don't buy anything chromed any more.  No matter how thick or how high the quality of the chroming process, it only takes one rock to chip off a piece and the rust begins.
Ahh.  I see.  That's probably a good choice, and will look good on your truck.  They look like nice bars.  If they were S/S I might think about looking at them harder myself.
We don't have much snow down here-seems like more each year, but still not much. When it snows, they put down sand.  But, I fully understand how bad salt is for your whole truck!  That would be tough to try and keep a truck in really nice condition.  Thanks for the replies and info.
I'm still waiting patiently for my "Oval Tube Steps" from Westin.  I think they jumped the gun on their release date.  I placed my order in early March, and now they are saying the end of this month they will release the bars.  They claim the black ones will be out first.  That bums me out a little, because I ordered the chrome plated aluminum bars for my truck.  :)
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
