Crappy 4x4 Indicator Strikes Again...
Ok, so lets start with yes, it is my fault. I left the truck in 4x4 because my driveway is pretty sloped and in park it will slide down into the street if there is snow. So yea, my bad. But you would think that they could just make the damn 4x4 indicator on the IP light up. I mean, come on, the light is already there. You cannot even see the other one from a sitting position unless you hit your head on the window....
Now the good part. The wife drove it from my house up to the pool place, they to daycare to pick up the kiddo, then decided to take it out of 4x4. Mostly straight driving, 2 small parking lots, probably 10 miles max (and it is dry outside). Aparently the fact that it would not turn and probably groaned like a bitch did not indicate any problems, she was waiting for lights and bells???
So, how bad is it Doc? Will it live?
I don't understand, you're worried because she drove it 10 miles in 4 wheel drive?
If the truck can't take that kind of "abuse" then I wouldn't want it anyway.
Truck will be fine.
Has anybody played with the Tech2 to see if they can get the light to illuminate in the IP?
Can it be activated so that it comes on when in 4x4? Seems logical, too logical, perhaps all it needs is the bulb added to it. (Yeah right.)
I just want to hear from someone else that there should not be any mechanical damage. That and when she called me crying saying that she thinks she killed my truck she said it was making horrible noises before she figured out it was in 4x4. I have driven my old jeep on dry pavement in 4x4 before and actually killed the engine. I just want it to be OK when I get home, know what I mean?
Truck will be fine.
My old 2005 Silverado had it in the IP and I got it to come on by using a base tune from a lower trim package that did not have the buttons but had the floor shifter I think.
If I could figure out how to do it to this one I would but I could not find anything, nor could the guys at HPTuners, in the code that allowed that. But like you said, maybe the Tech2 will do it.
Make her feel terrible for it. Then tonight you will score. But really, nothing is wrong with it. Chalk it up to experience, and let it go.
I like that approach. :lol:
Good point but not this week... :lol:
I know, I know....That is why I started with "I know it is my fault"
Yea, I know, but when it snows they do not clear our streets until VERY last. Sort of rural. I did not figure that engaging and disengaging 4x4 every time I touched the gas would be good for it either (since autotrac only locks the front end when it detects slip). Know what I mean?
She didn't hurt it. I have givin plenty of 4x4 hell over the years .I would not go round and round in circle forever though. :lol:
It won't hurt a thing. I used Autotrac almost exclusively (in the snow) for almost 8 winterss in my 2000. It is designed for it.
I would say your fine, i have done the same thing w/ my truck last year when i went from a snow storm to sunny skys, lol....
As for the auto 4x4, i only use it when there is combination of dry pavement and snowy roads.... when you have nothing but snow on the roads or ice , lock it in 4hi and keep it there since the constant locking and unlocking is unneeded stress .
    250.3k
    Ragg-Boy
    Ragg-Boy
  • Who's Online   4 Members, 0 Anonymous, 866 Guests (See full list)
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
