I Got Me A Fleetanater! :(
alaska511
It's my service loaner. My new dealer down here gave me an '08 LT 4wd while mine is in for the rear main seal leak. Rollin' the 17s for a while :lol:
It's my service loaner. My new dealer down here gave me an '08 LT 4wd while mine is in for the rear main seal leak. Rollin' the 17s for a while :puke:
You poor soul. :lol:
At least I got to experience Jeff's statement about how they ride so much better...what a crock!
Do you feel any dumber when you drive it? :lol:
Kinda! I picked it up this morning, and the TPMS was warning me on 3 tires. Knowing that it was likely due to the 22* temps, I went in search of the DIC button to see what the pressures were...alas, there is no freakin' button and I almost rear ended a car lookin' for the damn thing :puke:
:D
I think my 20s ride every bit as good as the OEM 17s did. They darn sure handle better (and look better)
My poor Silverado and my Ram are both in the shop. Silverado needs the transmission fluid changed and the rear seal replaced.
:D
Sacrelig :lol:
Atleast they gave you a Silverado and not an Aveo.
So far they have been great! I was very suprised when the service advisor rolled up with the Silvy :lol:
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
