Help With Color Choice - 08 Denali Xl
Wrestling over Stealth Gray or Summit White.
White available with ebony and cashmere interior.
Currently have a Summit White 07 Denali shorty with ebony, and I think ebony is the way to go, cashmere looks like it could be a nightmare to keep clean, especially in the long term.
Thoughts on looks but also color "maintenance" as I owned a black truck once (prior to clearcoat) and swore I would never own black again, is this blue
a cleaning nightmare?
Thanks for the help!
I prefer white.
I recently bought a red truck and still wish I'd had found a white one like my last two.
Thanks for the replys......keep 'em coming.....
Those with gray colored trucks......how's the work keeping them clean?
Anyone with expierence with the cashmere interior (that name just doesn't sound right for a truck!)?
Very little work...I love it. I had Onyx Black before this one and that was a nightmare to keep clean. I'm a detailing freak so you can imagine the amount of time it took to keep the black up to my standards. That being said, it looked damn good WHEN it was clean. I said that I would never go back to black but the new Carbon Black Metallic is very nice. I think the metallic in the paint will help hide a lot of imperfections and be more forgiving than the Onyx Black so I will consider that color if it's available when its time to replace this truck.
Ahhhhhh......a Stealth Gray owner checks in......looks awsome in your sig too, thanks for the heads up on the finish maintenance!
Stealth Gray! :)
As for cleaning, the stealth gray is pretty simple to take care of, honestly.
I agree with the stealth gray, that is what I have and the cleaning/maitenance is not that bad. The color also appears to change in different light. It can look like gray, blue or green depending on the lighting.
I don't care for stealth gray on Denalis for some reason. Denalis look best in either white, black or that awesome deep red color they have. Since black and red aren't options, I vote for white all the way :)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
