Roadmaster Active Suspension
I would too, I am very interested in this product.  I don't haul too often, but when I do, it is usually 5-6k lbs.
I am hoping that they will perform as sway bars and traction bars to some extent. It is impossible to get sway bars for the 3/4 ton suspension and I am tired of the roll, I know that they will help prevent axle wrap.
I saw that product about a year ago on the Shadetree mechanic. Looks like it helps quite a bit under load.  Let us know how you like it :)
I've had them on for almost two years now. Works exactly as its advertised and has given absolutely no problems with close to 20K miles on them.
It doesn't change the ride characteristics at all when the truck is empty and adds support only while under load.
If you want to reduce the bounce in the ride, I also installed these which made a big difference in ride quality along with both edelbrock and bilstein HD shocks. (Had the edelbrocks now have the bilsteins)
http://www.velvet-ride.com/
