Scfi Fuel Pump Question
dwfatboy
I have a 72 K5 Blazer with the powertrain out of a 98 Suburban with the 5.7. I pulled the fuel tank and the guy who I got the Blazer from did a butcher job on the tank to get the fuel pump and sending unit in the tank. I want to replace the tank and use an inline pump. Most of the pumps I find are running at 80-85 psi. The service book I have says the enging specs at 60-66psi. Would the 80-85 psi be too much for the pressure regulator and return? I am planning on running a stock tank and sending unit with the inline high pressure pump. The tank and pump that are in it now work but I think he must have used 2 tubes of caulk to get it to seal. It just don't feel safe running it the way it is. Any info or suggestions are greatly appreciated. Thanks
HOLY 952 POSTS, BATMAN!
WTF?
WTF?
He's trying to catch up with you, Jim. :D
Site must have been really messed when he posted......
WTF?
I agree... even Brian would not do that. :D
NICE AVATAR! Welcome to the Clown Club!
When I was gone for 4 days, I had 18 pages of new threads to go through. I've been gone for less than 24 hours, and I see 13 new pages. I thought we were all just really talkative today. :D
I bow to you 72K5er, a member for less than a few hours and you've already got three wrenches! I've been a member for a year and only have two!! LOL... I do need to try a little harder I guess... Welcome! I hope the mods can fix you up soon, lol... I don't think a serious answer to your question will surface until then.
Hello,
The site has been having some problems, and your thread was posted a bunch of times. That's why most people are freaking out. As far as your question. Your regulator should handle it just fine, but I would be more concerned about your fuel lines. You may want to completely replace those with new fuel lines that can handle the 85 psi easily. Any general replacement fuel line will work just fine. If you go with a universal type fuel pump, you may be able to adjust the pressure as well. Good luck, and let us know what you end up doing.
-Al
Thanks for the reply. I don't know what happened. After I hit enter, it took a minute then my screen said "internal server error". I am sorry, I only wanted to post it once. I post in forums all the time and this has never happen before.
WTF?
He's trying to catch up with you, Jim. :)
I'm just trying to honor you. Oh Great Clown Master. :lol:
No worries. It happens here sometimes. More than we'd like.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
